Old 03-24-2012   #1
Default Spark knock at idle
I am getting spark knock at idle per the Tech one ....taking out 10 degrees....Flywheel?
Old 03-24-2012   #2
mike100
Default Re: Spark knock at idle
audible?
firing order goof or really bad gasoline?
Old 03-24-2012   #3
It picks up on the Tech 1, I really can only hear the flywheel slightly....
Old 03-24-2012   #4
mike100
before I replaced my injectors, my car would knock on the dual mass from time to time from an inj misfire (my dual mass has a little play in one direction, but is quiet until you turn of the engine and it decelerates to a stop).
If you can hear it constantly it must be knocking in both fore and aft movements??? does that make sense?
are you in a position to drive it?
Old 03-24-2012   #5
mike100
you could disconnect the knock sensor temporarily and drive it w part throttle accel. if something is amiss, you can definitely hear the LT5 ping with the windows down.
Old 03-24-2012   #6
I have a single mass flywheel...
Old 03-24-2012   #7
Lee,
What's the motor idling at? We can reduce the timing retard and bump the idle a bit. Also tune for the single mass. I wouldn't sweat it much.
Old 03-24-2012   #8
idle is 750
Old 03-25-2012   #9
idle is 750
Lee,
We could raise that a bit. What about BLM(s) and spark timing at idle?
Old 03-25-2012   #10
left 160
right 155
-4 at idle
