Does anyone know if any ZR-1's were built without the LTPWS system? I have a 1992 ZR-1 and when I bought it it in 2007 had no sensors. It was originally sold in Canada eh! This winter (yes it's still winter here) I'm doing a bunch of upgrades so I decided to get the sensors. When I dug into the dash and removed the DIC there are no bulbs or wires or sockets to put them in. I'm not really sure what it is supposed to look like in there. There is a blue connector just sitting there not attached to anything. Can someone show me what it's supposed to look like. I would like to have a working system, but I don't even know if the module is there.
Rich |
#2 | |
![]() Join Date: Dec 2004
There is also the list of RPO's under the lid on the center console lid, no?
I seem to remember something about the Canadian cars and some RF rule concerning our LTPWS .... I just can't remember what it was. You could go over to Corvette Action Center and ask Rob L. ( the site administrator ) as he owns a 90 Z Canada car. ![]() Tom
#4 | |
![]() Join Date: Oct 2004
Yes your car build doesn't include UJ6 (LTPWS). You can confirm that on your SPID label. How to add it? I don't know. If you were wanting just a "functional" LTPWS system there are some after-market systems that function much better than just the low-pressure warning, they actually display tire pressures. I would think it also substantially less expensive than adding the original. There are rim mount and valve stem mounting styles available I believe. Valve stem mount would be just a deflate, break down one side, install, inflate and drive off! Until you asked I certainly didn't realize that it wasn't included in the Canadian builds! Your RPO's that I expected Z49 (Mandatory Canadian equipment), U19 (Metric speedometer), V73 (Canada/US vehicle statement) and T61 (Daytime running lamps) are present. Last edited by WVZR-1; 03-10-2012 at 06:57 AM. |
#5 | |
Rich |
There were 11 Canadian export ZR-1's in 1992. Of those, only one was Yellow, #31.
Interestingly, in 1993 and on, the Canadian export ZR-1's did have Low Tire Pressure Warning System installed. Good luck with your project. Jim |
#7 | |
Rich |
#8 | |
#9 | |
Yes
#10 |
Just another data point, our 91 was CA delivered and has no LTPWS.
Don't know if the feature was common or normal on US deliveries. Cheers, eh? - Jeff |
