Old 03-03-2012   #1
gbmidyear66
Default Intermittent SES
I have had an intermittent SES problem for a while now - I hoped it would go away when I fixed problem with my throttle body. The throttle body rebuild fixed my Idle problem and IAC - but not my SES problem.
The SES light will go on for about 10 seconds, then go off, only while driving, and only while decellerating (no throttle). It does not show as a trouble code on my Auto-Xray 6000 scanner.
Does anyone have any suggestions / experience on how I might capture what is triggereing the SES? - I was thinking that a PC based scanner might do the trick?
I really hate to admit defeat and have to take it into a professional shop that has the GM scanner tools....
gbmidyear66 is offline   Reply With Quote
Old 03-03-2012   #2
secondchance
Default Re: Intermittent SES
Give it a little time. After going to headers and cat back, my Z threw intermittent code for a few drives then eventually cleared up. I suspect it took a while to relearn.
What you might do is disconnect the battery, let it sit for 20-30 seconds and reconnect. I believe this starts the learning sequence.
Old 03-03-2012   #3
Kevin
Kevin's Avatar
o2 sensors
Old 03-03-2012   #4
Anytime an SES occurs, a diagnostic code is stored. Pull the codes & see what you have. Try retreiving them by jumping the pins in the OBD port & read on the inst panel display. Always start with the lowest numerical code first. Fix that & any other numerically higher codes are usually cured. I have no idea why your scanner isn't retreiving the code.
Old 03-04-2012   #5
Use the paperclip method and pull the codes. They should be stored reguardless if the SES goes out.
However the AutoXray 6000 should see these codes as well. If it isnt im not sure if a Tech1 will see them.
Last intermittent code I use to see once in a while was a Cam Sensor fault
Old 03-04-2012   #6
gbmidyear66
Thanks for your help guys, I had a brain cramp and forgot all about the paperclip (which is what I used before I got a scanner).
My ECM is showing a code 24 - which I had last year (along with various other idle issues). I did some more digging on code 24, apparently it is set when ... "Vehicle speed was 0 MPH when engine speed was between 900 and 4400 RPM and throttle position angle was less than 2% for 4 seconds" - which is exactly my situ - only happens in motion on decelleration.
The VSS sensor looks painful to replace if you don't have a lift - I may buy the sensor and new tranny fluid and take it to a local shop.
Old 03-04-2012   #7
Im not sure but I think the ZFDOC has a tool to make that a little easier. GC
Old 03-04-2012   #8
gbmidyear66
Thanks GC - I'll check that out....
Old 03-05-2012   #9
I thought the VSS's for the '90 Z's were NLA?
I remember awhile back RockAuto had some that they were clearing out of their inventory and I ordered one for my 90. They called me on the phone to tell me that they were sure the VSS they were selling would not work for a 90 Z.
I dropped looking after that and didn't ever verify that they had the story straight.
Old 03-05-2012   #10
gbmidyear66
I believe that rumours of the death of the 1990 VSS are just that. I believe the VSS for post-90 cars is different.
I believe the 90 VSS is Standard Motor Products SC6 - just like this one...
http://www.ebay.com/itm/SC6-Speed-Se...a82c83&vxp=mtr
If not - I just ordered the wrong part....
Glenn
