Those of you in the know,..and the folks reading the threads know I had to tear my engine out and aprt due to a drivers side timing chain failure!
![]() ![]() And when I had to wait for the time to do the engine I redid lots of other things. Anyway I am trying to Piece together the pics and such to provide a pretty good thread on what has been going on since Oct. SO!..without further adeu..... First I got the car and the interior needed to be done: ![]() DONE(I have to redo the sill covers) ![]() ![]() ![]() |
After the carpet, I moved to the outside of the car and pressure washed and cleaned as much as I could
![]() ![]() ![]() CLEANED! ![]() ![]() ![]() |
Moving on, I rubberized and wire-wheels any rust I could find,..thats when I stepped up to the brakes:...SAD........!!
![]() ![]() This is the way they should look!,.. ![]() ![]() next was the wheels: ![]() I went ahead and media blasted them and put on a coat of glass black epoxy with a red reflective stripe...(this is mearly a test to see how black will look with the red and white on the car... ![]() |
After these pics I bought center caps with the corvette sybol...they look great:
![]() Next I wanted to work on the top end,....they werent destryoed, but not impressive... so I went to work... ![]() This was not so fun!!!,...the water leakage corroded the bolts and they swelled into the walls of the bolt hole...the hacksaw was the easiest part of the removal!!!! ![]() I did all the top end parts in a ceramic red with a 500 degree gloss clear coat after a full media blasting....The other pics are at home but I will add these later..but suffice to say the red paint looks like glass,.. ![]() ![]() I will be doing the cam covers in White to reflect the outside paint scheme. Moving on: |
OK...AFTER ALL THIS!!..I felt that it was time to move to the engine and see what was actually the culprit!,..sooooo I called some buddies and here we go!...OH YEAH BEHIND PHIL IS THE PAINTED PLENUM!!
Theres Phil! ![]() Theres Rich! ![]() Heres Paul! ![]() So we got the engine out and heres what we found: 5 bad valves bad valve seals little dimples on two pistons ![]() ![]() ![]() Last edited by oricale; 02-08-2012 at 04:09 PM. |
![]() ![]() ![]() ![]() So I *sent the heads out to C&C in Manasses,... *steam and pressure washed everything I safely could *ordered new rod bearings, seals, valves, gaskets, ect Engine CLEAN! ![]() ![]() heres the newly worked heads!!!! ![]() NEXT...ONTO INSTALLING THE BEARING AND HEADS!!! |
Next I pulled all the rod bearings and replaced them with Clevite bearing and plasti-guaged 4 locations throughout the crank....!(.042mm-.045mm)
Old: ![]() New: ![]() Using race engine building lube: ![]() A little trick to get out any crud in the ring space! ![]() And NOW we install the heads and Oil Pan!!!. ![]() ![]() |
ok so thats where we are for now,..I just torqued the heads on and now just waiting for new chains and tensioners..as well as all the other little doo-dads I need to finish and install it...that will be the next post when the engine is all back together....
NOW...here is whey I am fixin it..... The facing on the cam covers were gone! and these are also broken ![]() ![]() So..keep lookin in on me! ![]() ![]() ![]() |
#9 |
![]() Join Date: Feb 2009
Looking good man, almost ready for a gathering
![]() Rich
#10 |
Great work. looks like a lot of effort that will pay off soon. GC
