![]() Join Date: Jul 2005
I said I post a list of Mod's completed on number 99 as soon as I took inventory. I was going to give it a good once over and report back however it seems the guy recorded everything he's ever done. He provided 4 pages of spreadsheet entries which included all the Mod's, services and maintenance...
Here's his list: Engine: 368 cid 532 HP at 6750 rpm, 452 ft/lbs torque J&E forged pistions, file fit plasmy moly rings Eagle ESP I beam connecting rods, Clevite 77 race bearings New GM stock race bearings EA22H inlet camshafts, stock exhaust camshafts custom timed Custom porting of cylinder heads and injector housings Phosphor bronze valve guides and Teflon seals New valve springs with titanium retainers Matched Siamese plenum with 63 mm throttle body ZF Industries Prom with 7500 rpm limit Silicone Hoses Forced Air intake DRM Radiator Exhaust: Ceramic coated Watson headers Borla Exhaust Transmission and rear gears: W.R.P Short shifter 4.09 Gears (DANA) Suspension: Adjustable Coil-overs DRM with revised FX-3 Chip Bilstein shocks rebuild Ploy Bushings 30 mm Front sway bar Chassis: Roll Bar Under carriage cross bar Wheels: Fikse FM/5 18x10 front 18x12 rear Brakes: Front Wilwood 6 piston w/13 inch alu hat rotor Rear GM 4 piston with wilwood 12 in rotor Air ducting to front and rear DRM High volume master cylinder Brake bias adjustment control (in engine bay) this is what I couldn't identify earlier Exterior: Morrison Motorsports ground effects package Total cost: $41,642 All I have to say is wow... and I'm very ![]()
Ron Hanselman Founding Member #80 CM Lifetime Member #1093 1991 #383 Twin Turbo 1993 #099 Ruby, Jeal 368 w/Snake Skinner body 1961 White with Red Int Last edited by RHanselman; 01-13-2012 at 01:27 AM. |
![]() Join Date: Dec 2003
Nice
Get rid of the Borla and post up some pictures. Pete
![]() Join Date: Jan 2011
Wow what a great surprise. Now the big question is what else are you planning on doing to it?
![]() ![]() Join Date: Feb 2010
What a wish list for the rest of us!!
The Police are looking for you, You stole that car!
#7 | |
The ones i had were .230 pri .240 sec on the lift i will have to double check my files can't remember right now what comes to mind is .400pri 420sec again i will have to double check. Pete
![]() Join Date: Dec 2004
Hey Ron what kind of gun did you use.....just curious & just kidding! What a list on the motor! That reads like a "Who's Who" of sweet parts! The T/Q is a very nice number.
![]() Good Luck and play with her in good health! ![]() ![]() Tom
#9 |
![]() Join Date: Dec 2005
That car had been for sale for some time and I should have taken a closer look at it.. That is a lot of car for the $$ Nice pick up Ron!
enjoy and keep us posted on how she runs ![]() |
#10 | |
The Borla's are going to go... Anyone interested? I'm also going to sell the B&B's off #140. Last edited by RHanselman; 01-13-2012 at 11:36 PM. |
