Old 12-30-2011   #1
oricale
Default Boroscoping before finishing????
Hello All as you know I have been working on the Z for a while and I have finally recieved my new Injectors from FIC,..(Jerry I need to order another seal kit!)..Anyway I had a high RPM knock at startup that everyone on here is sure its a dual mass flywheel issue ect due to sureley bad injectors!!!,...Well..I am wondering if I can boroscope the psitons through the sparkplug holes to verify that there is not a head issue(valves slapping the pistons).....
AND....if it is in fact a head issue can I change the head in the car???
Also All my WAZOO buddies...I almost have everything to get this thing done...let me know if we can set up a time or day?????
1990 ZR1 #00077 (10Y022 PEP CAR)
1991 ZR1 #00517 ("Irene")SOLD:cry:
1992 ZR1 BLACK RED(2016
2009 Z06!! BLK/BLK rare Linen interior 707HP!!
2006 BLK/BLK Z51 (Just SICK FAST!)SOLD)
1996 BLK/BLK LT4 Grnsprt(sold...Twice!)
1991 RED/REDL98(Fell off the shipping truck:(
1980 BLK/RED L82(Sold)
1990 RED/BLK( sold.....In Japan)
2006 Mustang GT mach 1(sold)
1969 Mach(sold in Japan)
1969 Mach 1#2(sold)
WAZOO Member...
www.evolution-motorsport.com
facebook/evolutionmotorsportengineering
Your Local [url]www.Amsoil.com[/url] dealer/user..
*Victory Loves Preparation*
oricale is offline   Reply With Quote
Old 12-30-2011   #2
Default Re: Boroscoping before finishing????
Retiming the cams, etc would be a PITA....a motor can be pulled in about 4 hours, why not pulled it and address it and any other items....
Just a note, not sure how bad the sound is but the LT-5 has a known piston slap issue that was determined to not impact longevity of the engine or performance.....
If the pistons are hitting pistons, why not do a leakdown or compression test to see if there is an issue?
Old 12-30-2011   #3
oricale
Here is the earlier thread....http://www.zr1.net/forum/showthread.php?t=15800
I may want to do another compression check,..would that eliminate possible valve issues?
1969 Mach 1#2(sold)
WAZOO Member...
Old 12-30-2011   #4
If the valves are hitting they are bent and therefore compression would be down....leakdown would be better.....
Old 12-30-2011   #5
oricale
what do i need and can i do it in my garage?
1969 Mach 1#2(sold)
WAZOO Member...
Old 12-30-2011   #6
mike100
ON EDIT- Nevermind- just read your previous postings. I would pull the engine if you can positively diagnose it.
Old 12-30-2011   #7
Pete
Pete's Avatar
You still not figured/fix this.
If compression and leak down check good you don't need a boroscope or change the head.
You need to give more info, what you've done and checked already.
You check injectors,wires/plugs,coils?
Check engine light on?
Is it only do it at start up?
I would suggest take it to a pro and stop wasting time & money,guessing.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
