Old 12-07-2011   #1
sdycke
Default master debate
Hi there. Wont take up much of your time but just WHAT kind of master cyl cap is this and why does CA keep sending me the wrong one....sorry, sorry. OK. Its my '91 and if someone has any help with a part number or something to positively identify it so I can get a repleacement, i thank you.... cheers
sdycke is offline   Reply With Quote
Old 12-08-2011   #2
Daniel_Mc
Daniel_Mc's Avatar
Default Re: master debate
Looks like the one on my 89.
Daniel
Daniel_Mc is offline   Reply With Quote
Old 12-08-2011   #3
That is the cap from a 90 ZR-1 and all other L98 cars from 90 and earlier, I'm not 100% about the "earlier", but I know it's a 90. The newer master cylinders had a master with one large reservoir versus the 90 that had two small reservoirs. I'm just not sure when the change was made to the one large reservoir.
Old 12-08-2011   #4
PhillipsLT5
PhillipsLT5's Avatar
Try, Stan at parts, Tom Henry Chevy in PA
Old 12-08-2011   #5
limey
http://www.ebay.com/itm/10159584-CAP...item4aac5ae5c2
This seller has it, we also have it in stock, but a bit more $ than this.
It's GM part # 10159854
limey is offline   Reply With Quote
Old 12-08-2011   #6
sdycke
Awesome! Thanks for all your help. Its just that I ordered a replacement from CA and they send me something a little too small, and i try again and I get the same thing...and I wonder, is it me? I mean, I can read and I know my numbers....where's the problem...? Oh well. Cheers.
Old 12-09-2011   #7
WVZR-1
#10159584 as in the eBay link for brake master & it should do MY '91 and earlier. Who is CA?
Old 12-10-2011   #8
If you have trouble getting the caps post back because I think if I look I have spare caps....they used to come with the GM master cylinder rebuild kit. I am almost 100% sure I have them some place in my tool box or in my parts inventory.
Old 12-29-2011   #9
sdycke
Hey folks. Let me know Tom if the caps you may have are identical to the earlier photos. I ordered a pair of 10159584 from gm. Too small! What gives? enclosed are photos of the actual Master cyl on the car, and the original caps vs the wrong ones (that everyone says should be right) with an OD of 2 1/16 ". The ID of my MC res are 2 and three sixteenths. The numbers on my original caps are PBR K818-013 RE2. Wishing everyone a Happy New Year!
Old 12-29-2011   #10
Okay, I am going to go dig out the caps. Then I'll try them on my M/Cylinder....if they fit I'll post back and get your mailing addy and send them to you.
My caps are not like what GM sent you at all! Mine are just like what was on my M/C from the factory. I should add that I bought my rebuilding kit from GM before they went NLA on the kits.
