I pulled the alternator and is shows it being a 108 amp alternator,.!
??what kind of issues can arise from a low amp count on our cars?? |
Too many electrical issues to list. In short underpowered
![]() Join Date: Mar 2004
Cmon',..you know I wont reinstall it but it could be why the car is having issues !!
that it could these cars are battery hogs. swap it and see what happens
![]() Join Date: Feb 2006
It might not be able to keep up with the current load with EVERYTHING turned on. High beams, AC blasting, aftermarket sound system hogging the rest ... I think the stock alternator is 140 amps, but 108 should be enough for daily use. The trick is to make sure the battery terminal voltage is above 12.6 volts under full load.
#7 | |
#8 | |
![]() Join Date: May 2008
Joe Thomas Corvette Club of Michigan NCRS-Michigan Chapter Member NCM Master Ambassador NCM Lifetime Member Former NCM Board Member 1991 ZR-1 Melon Copper Metallic/Black 1992 ZR-1 Bright Red/Black (Sold) 1995 ZR-1 Bright Aqua/Gray (Sold) 2012 ZR1 Super Sonic Blue / Dark Titanium |
#9 |
As an example, fluctuations in battery voltage are compensated for by ECM modifying injector PW. However, you'd like to be at the power level where the vehicle and systems operate at optimally.
#10 |
![]() ![]() Join Date: Feb 2010
The build sheet for my 88 called for a 120 amp unit. I would think the later cars would be at least 124.
