11-27-2011 | #1 |
A question about loose exhaust manifold studs.
If the 2 that leak were leaking bad enough would it give the impression that the pan bolts were leaking,oily pan?Im in the process of some fluid changes and while Im under the car I wanted to tighten all the pan bolts but cant find any that are loose.Thanks.
