Old 11-19-2011   #1
BOB HDZ
BOB HDZ's Avatar
Cool SINGLE FULE PUMP
SINGLE FULE PUMP HAS ANYONE TRIED THIS? CAN IT BE DONE?
BOB HDZ is offline   Reply With Quote
Old 11-20-2011   #2
scottfab
scottfab's Avatar
Default Re: SINGLE FULE PUMP
I suppose it depends on what the flow rate is of the pump you choose is. The stock pumps if only one is used, is not sufficient to keep the pressure up at sustained WOT.
Scott
Old 11-20-2011   #3
mike100
a real hefty single pump might be hard on the fuel pressure regulator.
Old 11-20-2011   #4
BOB HDZ
BOB HDZ's Avatar
Cool Re: SINGLE FULE PUMP
I WAS THINKING LIKE ONE OF THESE! http://www.stealth316.com/2-fuelpumpguide.htm
Old 11-21-2011   #5
scottfab
scottfab's Avatar
Great info there. I think the walpro might fit without adding wire, relays, fuses or resistors. First step I suppose would be to determine the goal. I have read/heard that unless you're pushing >500hp the stock pumps are fine. If the goal then is to go higher then a new pump design and injectors would seem prudent.
Scott
Old 11-21-2011   #6
Bob,
What's the point? Why does it matter?
Old 11-21-2011   #7
BOB HDZ
BOB HDZ's Avatar
ONE LESS TO FAIL! & SUPERCHARGER APPLICATION
Old 11-21-2011   #8
Kevin
Kevin's Avatar
ah the infamous vaporwear blower.
Old 11-21-2011   #9
If anything, with a S/C you would need 2 pumps.
