Old 11-14-2011   #1
lcfman
Default ABS message on dash display
I have 2 screen message icons that have come up. One is ASR and the other
is ABS in addition to a red light indicator "brake light". I suppose it is the traction control and anti lock break system problem. Any help on how to
fix this problem. The car sets much more than driven. Its a 95 model. thanks
lcfman is offline   Reply With Quote
Old 11-14-2011   #2
Default Re: ABS message on dash display
Hows your brake fuild levels looking?
Old 11-14-2011   #3
lcfman
Just went and checked the master cylinder level is right at the minumum
mark.
Old 11-14-2011   #4
mark.
Fill it AND let us know how it goes. At the minumum during driving you may be sucking in air
Old 11-14-2011   #5
tccrab
tccrab's Avatar
You will more than likely need a Tech1 with the appropriate ABS module to read and reset ABS error codes.
TomC
'Crabs
TomC
'90ZR1 #792
Honorary Pirate
[/B]
