Old 11-11-2011   #1
STEWVETTE
Default REAR END OFF CENTER
I have seen online that some c4's have rear ends that appear to be off center and this might be a common problem. I have measured out my frame and all is in spec. And the rear end is centered in the frame. But with wheels and tires mounted on the car the drivers side wheel is out 1/4 inch and the passengers side is in 1/4 inch. Is this a common problem? Does any one else have this issue on there car? Its hard to notice unless you really look for it. Is this an issue with how they were built at the factory?
STEWVETTE is offline   Reply With Quote
Old 11-11-2011   #2
VetteVet
VetteVet's Avatar
Default Re: REAR END OFF CENTER
If you took a survey with a sample size of 2 (you and I), GM would have a perfect 100% average. Mine is about the same, maybe a little more so. Same situation with mine. Frame has been verified straight and no signs of impact or damage. It seems to be pretty common with the C4's.
Jep
Old 11-11-2011   #3
STEWVETTE
Thanks I thought that might be the case. If any one else has experienced this I would love to here about it. I'm curios how common it is. I'm going to take some more measurements on the frame rack just to see why the issue might exist from the factory.
Old 11-11-2011   #4
sammy
something you might want to look at is your camber settings on your rear tires .that can sure cause what you see
Old 11-12-2011   #5
Pete
Pete's Avatar
Come to Bowling Green and check it out it's more common then you think.
Heck i seen it on low mileage ZR-1's
I was just thinking of making a spacer about 1/8" just to make it look right.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 11-12-2011   #6
Spring sag. Driver side. The composite fiber spring tend to break and fatigue and lean to the driver side where most of the weight is (From the driver).
Its a very common C4 issue
