Okay. Bought Marcs chip for secondary throttle valve delete for my 91 because I really would like to make the car as trouble free as possible, and I didn't want to keep spending money on actuators, finding out if they are installed correctly etc.... so, the decision was made to just make the system as simple as possible as Paul Workman and others have recommended.
I have the plenum and IH on the driver's side off at this time (the pass side IH is not coming loose for some reason..help here, should I pry it somehow?) and can see the throttle plates with the two screws holding each one on. I really don't like the idea of wiring the plates open, but it looks like the heads have to come off in order to do it right...is this correct? If they heads have to come off, I will resort to plan two, that is, would it be okay to just unscrew the throttle plates and leave the shafts? I really don't like that idea either, but something about using wire to keep them open just reminds me of a hack job. Any help would be greatly appreciated. Thanks in advance. Last edited by Torchred96; 11-09-2011 at 01:50 AM. |
Okay, found this... I know, search...I was under the impression that there was only one shaft that went from the front of the engine to the back, but I see that that is not the case and the shafts are separate and each go in from the valley side, ie laterally.
http://www.zr1.net/forum/showthread....hrottle+shafts There is a product , jb weld might be the maker, that is like putty.. I believe it's two part, but it may not be. I have used it to seal leaky freeze plugs and it hardens like a rock in about 5 to 10 minutes. Can one just fill the holes with this putty? I see the plug that is recommended but is that overkill, or would I just be turning a good job into a hack. Last edited by Torchred96; 11-09-2011 at 02:35 AM. |
#3 | |
![]() Join Date: Nov 2007
P. |
Agreed, the Dorman plugs are dirt-cheap, and effective. I didn't use any sealant on mine, as they are a very tight press-fit.
since you have everything apart send it to pete for porting.
the plot thickens
![]() Join Date: Mar 2004
I guess I went extreme we welded over the holes and polished the area out. They are never going back lol
#9 |
#10 |
![]() It was a very Fung Shway thing to do lol
