Old 11-02-2011   #1
ZONER 95
Default Recognize this hose??.....
Found this hose floating around loose in the engine bay of my 95.....its only about 6" long and has a flared end like it would just pop into something......I've looked all over for its home without any luck.....any ideas?......found near windshield wash fluid fill....
95 ZR-1 #178
Black/Beige
Dunn Heads
ZONER 95 is offline   Reply With Quote
Old 11-02-2011   #2
Default Re: Recognize this hose??.....
condensate drain tube from A/C evap. look for a hole in the bottom of the housing, near the firewall.
Old 11-02-2011   #3
Concur. 100%
Old 11-02-2011   #4
ZONER 95
Thanks guys...will go check it out
95 ZR-1 #178
Black/Beige
Dunn Heads
Old 11-02-2011   #5
VetteVet
VetteVet's Avatar
The flared end should pop into a hole in the lower front of the blower motor housing. The other end should then line up with a nipple on the evaporator case.
Old 11-03-2011   #6
ZONER 95
Thanks....figured it out and she's back on.....Kevin
95 ZR-1 #178
Black/Beige
Dunn Heads
Old 11-03-2011   #7
Corvettes White
I do not think so. I believe this is the Blower Motor Cooling Hose. It conducts fresh air from the plenum to the motor windings to cool the them. Condensate drain is at the bottom of the case, This is on the side.
George
Corvettes White is offline   Reply With Quote
Old 11-04-2011   #8
VetteMed
George
I agree, George.
Old 11-05-2011   #9
ZONER 95
This is where it fit......thanks
95 ZR-1 #178
Black/Beige
Dunn Heads
Old 11-05-2011   #10
Corbusa
Is there some way to make sure it doesnt fall off again ? I'd hate to lose it while driving.
