10-31-2011 | #1 |
Sliding IAC counts...
Got the Z running again, but an old puzzle remains present & unsolved; in spite of new gaskets all round ('cept the TB gaskets which were changed earlier this year) with no change in characteristics.
What it is... On startup and the engine is cold, my IAC counts are in the 20s, but after it is fully warmed up and especially if it has been at or close to 7k+ rpm, the counts drop to zero. Anyone else notice IAC counts changing as the engine warms up? P.
10-31-2011 | #2 | |
Re: Sliding IAC counts...
Min Air on TB. |
11-01-2011 | #3 | |
Other than that, she's runnin' real fine - or as before, at least. Still have to figure out the tweak to eliminate the occasional hot-decel stall thingy. But, that's a post for another day.... Thanks, Dom. I'll let you know how that works. P.
11-01-2011 | #4 |
The secondary butterflies shouldn't be an issue unless they need to need to be cleaned. The 0 counts indicate too much air without need for IAC bypass. Assuming no other leaks, the min air and clean TB blades would be my suspicion. And yes adjust the min air for hot engine. In fact, I adjust it w motor running and just after fans shut off.
11-01-2011 | #5 | |
P.
11-01-2011 | #6 |
