Hi
I am going to drain the cooling system in our 90Z while I do several things to the system. Because I am going to take most of the long cold winter here in VT to do the work is there any downside to leaving the cooling system without any coolant? I can tape of the coolant pipes and tubes if necessary. My concern is with the air getting at the drained system could cause some scale build up or corrosion that will cause problems when I refil the coolant in the summer. Any thoughts would be appreciated. Best Regards, Don |
![]() Join Date: Dec 2004
Don, this is probably a dumb thought, but my first reaction to leaving my motor empty of coolant over the winter was:
Is the garage heated? If not, then I would opt to flush the system out very well using plain tap water as long as it has a low mineral content. Next I would do a couple of pure distilled water flushes. I would take my shop vac & suck out the remaining water from the block. Then reverse the vac and blow out the motor very well. Lastly I might get some of those absorbent packs, the small ones, and put them inside the I/H tubes and the w/pump inlet before duck taping the openings shut. Oh, forgot this on the fire side I'd do a winter lay up evolution too! Like you would do to a marine motor for winter storage. ![]() ![]() ![]() Tom
![]() Join Date: Dec 2003
FWIW:
Personal experience. When I built an engine for testing the new head gaskets, I installed a new waterpump. The engine was filled with plain water for the dyno runs. When testing was completed, the engine sat for about a month before took it apart. The new water pump impeller had a fair amount of visible rust already. Bear in mind, this was just the engine and it was rocked around on a hoist a couple of times during the handling after the dyno testing. Water stays in some areas, no matter what you do. About 2007, I had 30 LT5 engines (used test engines) at one time, that came out of GM warehousing. They were placed there, unprotected for the most part, in about 1991. Turn them over on the engine stand and coolant ran out. Pump impellers were heavily rusted above the coolant level. I'm not saying it will cause a problem, as Don asked, but am saying that I don't think you will ever dry out the engine completely to the point dissicant packs will do anything beneficial to prevent rust.
It will never be completely drained. As stated above Just flush it and replenish using the 50/50 rule equal water and distilled water.
#5 | |
Just because I'm curious, and totally off topic, but since you've mentioned them, where did those engines wind up and what is to become of them? Did you save any pictures of them? I didn't <right click, save as> when you had the pictures of them on your website. TomC 'Crabs |
Tom,
I don't mind if Don doesn't, since it's his thread. I sold several engines during the year or so that I had them and then sold the rest to one collector that moved them to Tulsa for his own personal collection. At the time his intended use was for a personal museum. To the best of my knowledge, they are still in storage in Tulsa. I'm not sure if his plans have changed or not. Re pictures: I still have photos of each engine. I wish I would have taken more, but I wasn't as astute on the historical aspect as I should have been. I have 210 pictures. Here's a photo of my LT5 man cave. ![]()
Hi All,
First Off, Please go ahead and use the thread A26B and anyone else that wants to join in as well. No problem on my end. Second, Thanks A26B, TomTom and GOLDCYLON for the great responses. I will leave the cooling system alone until spring as it is fully charged and good down to 35 below. I will just buy parts and be ready in April or May to start the projects. Hope you and your familys have a great Thanksgiving. Regards, Don ![]() |
Passing along some advice I was given. Never flush the cooling system out and then store a motor. There is always a chance that some water was left somewhere in the system and it could freeze. If you just drain the coolant, any bits that are left shouldnt freeze.
#9 |
![]() Join Date: May 2008
I'm not sure what would be accomplished by draining it?
The negative side is high and the positive side is low. Just fill with good coolant/distilled water and call it a day. |
