Old 10-21-2011   #1
Corbusa
Default oil change question
I got my amsoil z rod in today and will get a filter tomorrow. How many quarts will it take? ( not flushing the system ) , It had amsoil all along and I figure I'll keep it that way.. Thanks
Old 10-21-2011   #2
Kevin
Kevin's Avatar
Default Re: oil change question
About 10...give or take
Old 10-24-2011   #3
QB93Z
QB93Z's Avatar
For an oil change with a filter change I add 8.6 quarts.
Old 10-24-2011   #4
PhillipsLT5
PhillipsLT5's Avatar
I only get 8.5, would be nice to get out 10
Old 10-24-2011   #5
Kevin
Kevin's Avatar
maybe it is around 8...been a while since i measured it
Old 10-24-2011   #6
ZR1Vette
ZR1Vette's Avatar
Just a suggestion... I would put in 8 qts and start engine briefly and then check dip stick and then add 1/2 qrt at a time (start engine and shut down) until dip stick shows correct level. Engines with oil coolers etc can be tricky and it is better to slowly step up to oil capacity rather than over fill. BTW...most excellent choice in oil
Old 10-25-2011   #7
PhillipsLT5
wait 24 hour to drain down before check
Old 10-25-2011   #8
Yep the SM says too most dont
Old 10-25-2011   #9
Corbusa
I'll do the 24 Hr wait .. Does anyone here use Prolong or Dura-lube..? I would think it would help with the first few seconds of starting....
Old 10-26-2011   #10
bldavis11
You'll be one of the few who do. No need to over think this one. You're already putting in top-of-the-line fluids. I'm not certain how much you're going to gain on this one.
bldavis11 is offline   Reply With Quote
