Old 09-28-2011   #1
GRC
Default Hi-beam blue dash indicator light
I have a '91 ZR-1 that I plan to have PV judged by the NCRS. In reviewing the test procedure, I turned on the headlights with the ignition key in the off position. Then, I flicked on the hi-beams. The hi-beams came on, but the blue indicator light on the dash did not. If the ignition key is on, and the lights are turned on and flicked to hi-beams, the blue indicator light does come on. I want to know if this is correct from the factory. I have checked with owners of a '95 and '87. Their indicator lights come on with the ignition off. I have checked with a '92 owner and his indicator light does not come on unless the ignition is on. Can someone out there advise me if my car is factory correct? Jerry
GRC is offline   Reply With Quote
Old 09-28-2011   #2
Default Re: Hi-beam blue dash indicator light
my 91 is not available but I beleive the ignition has to be on
Old 09-28-2011   #3
Torchred96
I just went outside and checked mine. key off and brights on gives no blue light on dash...turn key switch to on and blue light comes on.
I have no reason to believe mine has been altered but it does have lots of miles on it. good luck!
Torchred96 is offline   Reply With Quote
Old 09-28-2011   #4
a1991zr1
my 91 and friends 90 the key must be on for inidcator light
a1991zr1 is offline   Reply With Quote
