![]() Join Date: May 2004
TODD CERAMI
21 PARK STREET BELVIDERE,NJ 07823 908 750 4383 TODDCERAMI@COMCAST.NET NO PAYPAL!!!!!!!!!! COLLECTIBLES: 3) Hamilton collector 90 zr-1 collector plate. $65 4.) WOODEN OODENS wood Morrison EDS car, 1/24 SCALE carved in wood, very hard to find. $175 sold 5)Both variations of the EDS/TOMMY MORRISON posters. Thunder & Lightning & the one with the Helmet & gloves. These are originals not copies like on ebay. $35 each. 6) Original GM press photos of the lt5 engine 8.5 " x 11" $25 each. 1st photo pictures lt5 engine in lower caption, lt1 above it. 2nd photo side view 89 zr-1, 3rd photo rear view 89 zr-1. 4th photo 92 zr-1 engine ,similiar to Dave Kimble see thru art. 7) 1992 corvette gm "Corvette America " license plate $25 8)1992 GM pro athlete brochure in original mailer $80 8b)19 89 zr-1 Dave Kimble print Puzzle mint still has cellophane on the box. $80 USED 9) 90-95 zr-1 tire bag torn zipper, bag inside new. $65 10) 90-95 zr-1 tire bag very missing pull on zipper nice bag inside new. $80(1) 11)92 & 96 (grand sport) corvette& zr1 dealer gm passenger guide book, 25 pgs on corvette, options, specs, color charts. thick books $40 each ld 15) Tensioner, (RH) Sec Tmng Chain, 90~95 #10174324 reset by Marc Haibeck. $100(2) 16) Housing, (RH) Timing Chain Tensioner, 90~95 # 10110972 $ 75(3) 17) Secondary Port Vacuum Reservoir (Part #10067563) holds vacuum $65(2) 18) 90 right front bose amp/speaker 16166491, makes noise. needs amp rebuilt $35(1) 21) round plastic cap that goes on end of power steering pulley, usually missing $15 N.O.S (new old stock) (*) = quantity available. All parts Original GM not aftermarket(unless noted) 2) New Corvette 90-95 spark plug wires set with "corvette lt5" writing .mint in sealed bags/boxed . $340 for the set.(2) 3) map sensor brakcet attaches to rear of plenum #10067781 $50(2) 3a)90-95 lt5 valve guide sealed in bag # 10090575 $20 each ,(25) 3b) N.O.S GM red replacemnet wire,same as above but no "corvette-lt5 " lettering. Sealed in bags, no box. $70 for the set(5) 3c)n.o.s. 93-96 Corvette brushed steel center caps # 10137865 set of (4) $95 (1) 4a) A1097C gm air filter in box $40 (3) 5a) NOS PF970C & these have the correct part # 25014155 black, passed NCRS top flight with this filter. The ones without DURAGUARD are impossible to find. PF970 filter are blue part #25011441. $30 each(25) 6) cam cover bolts #1514330, sealed in bags. Attach cam cover to head. $5 each. I have quite a few of these.(10) 7)cruise control servo #25074627 $55 mint in box.(1) 8) 90-93 Corvette ZR-1 LT5 Cover, ECU Wire Harness 10098903 $70 (2) 9) Secondary Actuator solenoid # 1997222 $75(6) 10)90-92 driver side door handle plate, the one with power window & mirror switches(no switches) $75 #10253103(1)sold 17) 1990 Power steering reservoir cap (orange lettering ) # 26032950 $35(1) 20) Round Filter, Secondary Port Throttle Switch # 10159525 $12 (2) sold 1 left 21 ) Shield, Alternator Blade 1990 - 1995 Model #10153529 $25 (2) 22)SUPPORT Right Rear STAB SHaFt sway bar bar BRKT 14064521 $25(1) 23)SUPPORT left Rear STAB SHaFt sway bar bar BRKT 14064522 $25(1) 24)RR SWAY BAR LINK bracket 14060113 holds bushing $20(2) 25)Rear sway bar bracket, holds bushing on sway bar 3913863 $15(1) 26)Rear sway bar bracket, holds bushing on sway bar 3913862 $15 (1) 27)Aftermarket 25 mm bar polyurethane rear bushing set prothane brand in sealed package part # 7-1145-bl $20 (1) 28)round SWAY BAR INSULATOR BUSHING GM INSULATOR 14060114 $12(2) 29) # 14060115, BRACKET STABILIZER SHAFT $15 (2) 30)Original gm Gasket, Set Coolant Outlet Tube 90~95 $12 #10168677 (1) 31)exhaust manifold round spacers #03983422 $5(4) 32)Hose, Fuel Pressure Regulator 10110987 $25(1) 34)Hose, PCV Valve Connector 1991 - 1995 # 10174350 $50 (2) 35)Hose, Cruise Control Servo Vacuum #10110989 $40 (2) 36)Grommet, PCV Valve, 90~95 14078872 $15 (1) 37)connector pcv upper 10153503 $40(1) 40)original gm wheel weights painted grey different sizes 3 oz, 2oz etc you get 10 weights for $25 46)Condenser, A/C 1990 - 1993 # 52456459 $250(1 52) nos 90 cam cover emblem $100 TODD CERAMI 21 PARK STREET BELVIDERE,NJ 07823 908 750 4383 TODDCERAMI@COMCAST.NET NO PAYPAL!!!!!!!!!! Last edited by 91vettezr1; 10-01-2011 at 05:10 PM. Reason: updated list |
#2 | |
![]() Join Date: May 2008
Interested in the ECM bracket
Also like one of the cam covers the one with all the signatures Last edited by RUSSELL; 09-17-2011 at 12:32 AM. |
I would like next choice on cam cover... Can you please email photos.
#5 | |
![]() Join Date: Dec 2005
Todd,
Interested in some items. Questions on two before I buy them. 19)Hose, Secondary Actuator Vacuum Control Valve #10146221 , holds vacuum $35 (1) Is this the hose set or the valve? The number is for a hose set I think. 18) rear license plate screws, correct with torx head and washer (4) in a pack $18 (3)2 sold 1 left 19)17111800 Clip Retainer, Fuel Injector, 90~95 bag of 8 $15 # 17111800(1) 38)vacuum hose from sec pump to under plenum #10098477 $20(1) 39)fuel injector o ring kit 17113544 $20(1) Is this only the primary 0-rings or something else? Thanks, John ![]()
1968 convertible Lemans Blue, 1986 coupe Medium Blue NCRS Top Flight (sold), 1990 ZR1 #2529 Red NCRS Regional and National Top Flight (sold), 1990 ZR1 #2124 Charcoal Metallic NCRS Top Flight 2010 & 2018, 2003 Anniversary Red Convertible (sold) |
#7 | |
Todd,
PM sent. Thanks, John ![]()
#9 |
TTT, for a great zr-1 part seller.
Thanks Todd for the parts! ![]()
#10 |
