- The fluid in my P/S resevoir looked like used motor oil (very well used), so thought I should change it.
- The new fluid I bought is clear. I've now drained and filled the resevoir (turkey baster) 3 times now, and it's still dark brown, maybe a little less viscous than the first time. - Am I ever going to get clear fuild? Is there any gain to keep draining and refilling the resevoir? (I've already used up the full liter I bought) Glenn |
![]() Join Date: May 2008
Use a turkey baster to suck as much fluid as possible out of the reservoir.
Re-fill the reservoir (don't overfill!). You'll need to place the cap in a few times, removing it to examine the level. When full, screw the cap back on. Start the car. Move the steering wheel from full lock left to full lock right at least 4 times. REPEAT STEPS Several times! It's a slow process but you will get there. |
Maybe after 4 liters and exchanging the fluids after repeating a rack to rack then turkey baster procedure.
Yes, of course I drove the car between cycles of replacement of the reservoir.
I'll get some more fluid and give it a couple of more cycles and see if it cleans up Thanks |
![]() Join Date: Aug 2006
Following is the instruction from Cardone website:
The #1 steering problem CARDONE encounters during analysis of customer returns is failure related to contamination in the system. Failure to flush the system correctly can lead to several premature issues such as binding, poor turnability, leaking, hard steering or noise. The processes below will greatly minimize steering system contamination while also preventing excessive air from entering the system. During the flushing process, the engine is not running at high RPMs. This does not allow air to enter easily into the system, but bleeding must still be performed. Use this process to properly flush the steering system when replacing any steering component. Remember that skipping a step in the process usually results in a comeback.
I don't know what the access is like to power steering hose for our cars. |
