Question Number 2:
Several months ago we bought a Vehicle Anti-Theft Bypass module. The reason for this being that our Black Beauty loves locking up at 'thee worse' of times. We've heard from various sources that the 90's VAT system is questionable at best, however the instructions for installing the bypass have us a bit lost. It states there are two black wires coming from the ignition switch, however there are 'various' wires below the steering column. If anyone could potentially give some advise for properly installing the Bypass, and locating the VAT wires we'd be grateful. We've removed the airbag wire in hopes that it will not deploy while we work on our Beauty; any clue if this will keep the airbag from activating? --- On another note; Thank you Marc~ it 'was' the Blower Module; we are in the process of ordering a new one now. ![]() Last edited by Rhapsodos Genesis; 09-12-2011 at 07:51 PM. |
![]() Join Date: Mar 2004
Good to have you here. Pull up a seat and make yourself at home.
![]() Join Date: May 2007
I presume that the blower is the one for the heater and AC. I also presume that you have the electronic AC control system with the digital temperature display on the control button panel. If so the blower speed regulator might be shorted on. You could try replacing the regulator module. It is very easy to do in five minutes. It is a common 1990 to 1996 Corvette part. It would be easy to borrow a module from another car for a test. The module is located on the right side of the engine under the flexible fuel lines. It has two electrical connectors. If you remove the connector with the large red wire the blower will stop when the car is parked.
Best of luck. |
@FU2: Much obliged~
Its good to be here. @Marc: Your a lifesaver, everything in the vehicle is stock. I'll give her a look. |
