![]() Join Date: Aug 2006
Are they the same between the early years and later?
Also, any difference between the front and rear except for the wire length? |
#2 | |
![]() Join Date: Feb 2009
Yes there is a difference between the early and later cars as far as the actuator. Has something to do with the amount of rotation in it makes. Rich
#3 | |
Actuators are the same for all years of FX3, My 91 has a 92+controller and shocks in it, but with the original actuators. Front and rear are interchangeable other than wire length issues.
Speaking of actuators, I have a complete set if someone needs them.
Yun,
Scroll down on this page from Captain Z CNC web site and he shows later style actuator gears for $35 http://captainzcnc.com/id4.html
#9 |
Phil,
Those are for gears on top of the shocks. I think one of my rear actuator planetary gear (inside the actuator) is busted and periodically gets hung up tripping the light. I noticed partially broken planetary but it was working befor. |
#10 |
If they are doing actuator rebuilds seems they would also have replacement planetary gears. Wouldn't hurt to give them a call.
