![]() Join Date: Aug 2008
Who has them on their Z? What kind of gains do you typically see with them?
![]() Join Date: May 2010
Hey Rich,
I have them but have no ideal the gains since they were installed with everything at once. I have SRP pulleys (entire set) and love the quality, fitment, looks and had no issues at all with it. If developed by Randy Woods and father then I trusted it for what it stated and great folks that are way, way, way smarter than I will ever be. Sorry, that is all I can share about my experience with the product. ![]() Craig
Craig "ZR-1 NO KA 'OI" "ZR-1 ICHIBAN" 1995 #228 Black/Black with Dunn Heads ZR-1 owner since September 2003 ZR-1 Net Registry Founding Member #0074 NCM Lifetime Member #2048 ![]() |
Too bad the entire set is not available. Im at that while Im there point now. Craig sounds like he has a great setup there. Anybody have a set here that they want to get rid of???? Or havent installed ?
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director ![]() 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 08-18-2011 at 12:30 PM. |
#4 | |
Ok got a few PMs from a few folks. Something the community should know. At idle the temperature can ride high faster due to less mass. Does this makes sense. These folks have upgraded their radiators.
Where is TomTom when you need him ![]()
![]() Join Date: Mar 2004
Got the Wood's pulley with an ATI damper on the 441.Fluidyne radiator too.....no heat problems here.
#7 | |
-Andrew |
Your not confused. I was. That was what I was pmed. The waterpump moves slower at idle
#9 |
![]() Join Date: Dec 2004
Aye,Aye Cap'.....reporting as ordered. Yea, I thought about the 10% under drive would be a help for the high rpm by pass of our cooling systems...but ya can't have something for nothing. Yes in theory at low rpms the pump will move less water so the temps would have to rise a bit.
I had thought a 10% reduction would give us a bit bigger cushion on the twisties so you can hold that 2nd gear longer in tight Essses. At low speeds the pump output would have to cause the temps to rise a bit just because the pump is moving less volume due to turning the impeller less. Ya can't have your cake and eat it too! 5500 rpms = the complete by-pass target rpm on a stock system. No circulation thru the rad core. 10% reduction in pump impeller speed = only yields a cushion of 550 rpms....which is useless if you're in 2nd gear @ 6500 thru a series of Esses! Drag racing application only is JMHO, if your a road racer this will not answer the sustained high rpm volume that gets by-passed because there are no radiators that can handle the volume our w/p's put out. I had thought about buying these but the radiator core is still the issue and I'm not calling some F1 team to make me a radiator that will handle 100 gpm flow.....it's cheaper to redesign the impeller to lower the flow rate, JMHO. ![]() ![]() Tom forgot this, in drag racing where engine acceleration is related to reducing rotating mass, these pulleys would contribute to less rotating mass so less hp is lost thru parasitic drag which leaves that hp to accelerate the car. Just like the Fidenza flywheels let the motor turn up faster than a D/M flywheel.
1990 ZR-1, Black/grey, #2233, stock. ZR-1 Net Reg Founding Member #316 & NCM member Last edited by tomtom72; 08-19-2011 at 08:19 AM. |
#10 | ||
![]() Join Date: Dec 2003
Tom,
Just exchanging some thoughts with you on some of your comments about fluid flow, no offense intended. Quote:
There is another factor that also come into play, coolant velocity through the radiator. Removing the thermostat completely in many cases results in overheating. I Fluid velocity affects both heat absorption and dissipation. Back pressure in the cooling system would also need to consider the flow capacity of the thermostat. If the flow capacity through the thermostat is less than water pump output, then that problem must also be addressed, regardless of which radiator is used. I am a believer in the modification originated by Lingenfelter, drilling 3 or 4 small holes in the t-stat flange. This whole issue of the high flow water pump, the bypass system & damaged radiators could really use a good evaluation, but would require setting up a test apparatus to test all known radiators and the thermostat housing for flow capacity, just to see if the bypass system could ever be eliminated.
Jerry Downey JERRYS LT5 GASKETS & PARTS http://www.jerrysgaskets.com 1994 ZR-1, Black/Black, Lingenfelter Aerobody, 416cu in, 3.91 gears, coil-over susp, Brembo brakes, etc. 2016 Black-Red, 3LT-Z51 Auto 8-speed. Last edited by A26B; 08-19-2011 at 03:37 PM. Reason: missing keystrokes |
