Old 08-13-2011   #1
Default Shift Lite A Pillar Install
This is a Raptor I am using but the Harlan is nearly identical. It uses the diag harness connector for switched power and tach feed. Then a simple extension to ground somewhere on the block. I use the MAP sensor mounting bolt. Plug and Play.
Easy routing through door gasket and then tucked between pillar and IP pad. "A" pillar location also makes light easily accessible for changing shift points.
