I do some stupid stuff, but this morning, while leaving for work at O'dark-thirty, I did something really stupid, and misjudged how much room I had between the rear bumper and the fencepost. As a result, the rear quarter panel on the driver's side is cracked and buckled outwards. The rear bumper cover is scratched but not cracked. Now, the car is far from cosmetically perfect, but the outward buckling is obvious and is going to be a constant reminder of my stupidity. I'm hoping maybe there's a way I can at least get the area to sit flush as it should, and I'll just touch up the scratches and wait until I can afford a complete repaint, for a proper repair to be done. I'm attaching some pics, thanks for any advice.
-Andrew ![]() ![]() ![]() |
Looks fixable to me.
VetteDaddy is the fiberglass expert.. Hope he agree's! ![]() David |
![]() ![]() Join Date: Feb 2010
Dave's way too kind and easy with the "expert" word. LOL
There's an L shaped bracket glued to the 1/4 panel. The rear bumper wrap around attaches to this piece. Something is either in a bind or bent where the L shaped steel bracket attaches. You should loosen the bumper wrap around (lower 1/4 part of bumper) and see if the L shaped piece bracket is bent. I believe the bumper attaches to the bracket with 8mm or 10mm screws. The SMC fiberglass an be repaired. It may have to be cut in the cracked area to relieve the pressure that's causing it to bulge, when it gets repaired. It will need re-inforced from the backside and cosmetically repaired from the outside. It will be fine when done. Just make sure that the repair materials are SMC friendly.
![]() Join Date: Jul 2004
Try lord fusor and evercoat they are what I use.
Like He said you need the products specifically for SMC panels. Now if the damage did not crack through to the back you really shouldn't need to put anything on the back side but that bottom edge could use a little more work than the rest First things first SMC will bend under pressure so That bumper needs to come off relax that quarter and see how out of wack it really is or just take off the parts on that corner. You have some bracing for the rear bumper bolted in that area it could be pushing on it as well I could fix this for under $1000 but you are a long way from me. If you want a full repaint I can do it but it will cost more depending on the level of the job you want done.
JOHNNY P Currently own 90 ZR-1 #845 DRM 500 engine package 90 #226 Parts car Hit me up if you need anything. Last edited by phrogs; 08-12-2011 at 12:06 AM. |
you're less then 2hrs from me johnny, mind if i call on ya if i ever need a hand?
![]() Join Date: Aug 2008
If you pay to have it fixed your looking at $2K easy. My damage wasn't near as bad as yours when that lady decided to merge into my lane.
![]() ![]() ![]() And it cost $1852. Luckily her insurance paid for it. Didn't cost me a dime and looks awesome. |
#9 |
Once the material is stressed to the point of cracking the surface on the front side, the inner strands are compromised. The outer surface needs tress relieved and then the backside does need the structural
integrity restored. Otherwise, the repair will eventually bleed through.
#10 |
DAMN ITs fixable but DAMN Bro
