Old 08-07-2011   #1
65ZR1
Default Bunch of parts for sale.
Cleaning out the garage. The parts were from my 8000 mile 94 donor car. I have guessed at some of the prices so if you think I am out of line, just let me know. Shipping is extra.
Drivers and passenger seat tracks, the drivers frame is twisted, 150 Pair
rear sway bar
ABS pump and EBTCM 100
Rear factory rotors, mint, 40
Brake stainless flex lines 50
Oil cooler fittings in block 15
Oil cooler 125
Rear ABS sensor wires 1
94 air bag module 20
94 PKE module 75
90 FX3 module 100
94 LH air bag sensor, mounts to frame, 25
power seat harness and relay module 75
94 TPS interface module 20
94 power mirror switch 25
94 Full power switch and key 150
cruise module 20
94 LH power window switch 50
RH power window switch 25
94 ECM holder and wire cover 50
All AC heater vents 20
Interior air bag sensor #10210848 15
2 PKE antennas 10
Rear camber rod #10210848 20
Steering column parts: horn ring, multifunction switch, ignitions switch and key, turn signal switch 50
Rear camber rod brackets at diff 10
Gas filler boot 15
CHMSL ( white ) 40
90 AIR blower 20
94 wiper motor, no pulse unit 50
power steering cooler 100
power steering hoses, 1 low pressure, 1 high pressure 100
90 and 94 AIR valves 30
emergency brake handle 25
brake pedal 10
hood realease and cables 25
front and rear sway bar brackets 25
94 negative battery cable 25
3 wheel center caps and 19 lug nut covers 15
various plenum hoses and lines and fittings
I think thats it
65ZR1 is offline   Reply With Quote
Old 08-07-2011   #2
Default Re: Bunch of parts for sale.
94 rear view mirror 20
are the joints tight on it? good shape? Shipping to 60172? will you take paypal?
Old 08-07-2011   #3
What brand are the brake lines? Front and Rear? If Jeff gets the mirror maybe you can ship everything in one box. I live a mile from him.
Old 08-07-2011   #4
zrss
I'll take the gear shift knob. Paypal? My zip is 59405.
zrss is offline   Reply With Quote
Old 08-07-2011   #5
65ZR1
The mirror is in excellent shape and the joint is tight. I will get a price on shipping for you.
Old 08-07-2011   #6
65ZR1
I will get a price on shipping for you Jim.
Old 08-07-2011   #7
65ZR1
I should have been more clear. These are the lines connected to the master cylinder.
Old 08-07-2011   #8
VetteMed
CHMSL, is the paint in good shape? lens and lamps included?
Old 08-07-2011   #9
Ok. Thanks.
Old 08-07-2011   #10
DDSLT5
Could I get:
Clutch line (20)
90 Vacuum pump (100)
outside air temp sensor (10)
Thanks - you're in Cambridge? I can come and pick this stuff up tomorrow if you like.
Dwight
DDSLT5 is offline   Reply With Quote
