Old 08-05-2011   #1
mgbrv8
Default What is this connector?
The one with the fuse I know what that is now the other one I am not sure and I cant see its female end.
Old 08-05-2011   #2
mgbrv8
Default Re: What is this connector?
Not to worry found it.
Dave
Old 08-05-2011   #3
Kevin
Kevin's Avatar
what was it
Old 08-05-2011   #4
mgbrv8
Modual attached to the inner fender liner. It was one of those things were you tell yourself "mind as well put this on and figure it out later." when I picked it up I saw the modual attached to it and I said to myself "dumazz ".
Old 08-07-2011   #5
What year is the car?Ive been under the hood of my 91 and have never seen this.Its always nice to know where all the fuses are hiding.
Old 08-07-2011   #6
mgbrv8
The inner fender cover in front of the battery there is a modual and a fuse hat mounted there side by side.
Dave
Old 08-08-2011   #7
The fuse is the vacuum pump over at the right headlight and the "module", a rather elongated rectangular box is one of the two secondary injector drivers. The other 2* driver is above the battery power block....if I remember correctly.
