My grandmothers car a 1986 capri with a 305 and a E4ME computer controlled carb. once you get it started it runs great but its the first cold start that takes for ever. It was rebuild about 3 years ago. Any advice gentlemen. I am kinda in a pickle and no one around here messes with carbs anymore I dont want to just tear into it and mess things up. I am tempted to throw a edelbrock carb on it but then i have to swap the distributor and she will have a check engine light. Any help would be greatly appreciated
Dave Last edited by mgbrv8; 07-20-2011 at 11:54 AM. |
![]() Join Date: Mar 2004
Presuming that the choke is working properly.And the fuel filter is ok.Put a fuel pressure guage on it if you can overnight. Idea is that the fuel pump anti siphon valve has gone bad or has a little wad of debris in it.
Make's one think about what the new "fuel" with at least 15% methanol is doing to the system. Good Luck. |
![]() Join Date: Feb 2006
Pick up a rebuild kit - the 10% ethanol has probably destroyed an internal seal or gasket.
But first make sure the engine coolant temperature sensor input to the ECM is working - it sounds like there is no cold temperature enrichment happening.
“Buy the best example of what you want, and pay whatever it takes. That way, you cry only once.†~ Bruce Meyer |
305 in a Capri?
You need to find a OLD Guy for help, remember they rule Younger guys, carbs? That Quadrajet should have an electric choke, controlled by the computer. You want to check and see when the engine is cold, before the first start, press the accelerator pedal to the floor and release. Look at the top of the carb and see if the choke valve (flap) is closed. If it is closed it is working properly. If it starts and stumbles and dies, then you may have to adjust the fast idle screw to speed up the idle at cold start. There is an adjustment screw just under the choke housing facing towards the front. Clockwise to speed up the idle , counterclockwise to slow it down. You can speed up the idle speed when the choke is on and as the engine warms up, pop the accelerator pedal and the choke will release and the fast idle should return to normal operating idle. When the engine is warmed up and the accelerator pedal is "popped", the choke valve(flap) at the top of the carb should be open. The fast idle screw operates on a cam connected to the choke valve linkage and as the engine warms and the valve(flap) opens, the cam on the choke linkage turns and the idle speed should slow as the engine reaches operating temp. |
The thing is that when it is dead cold first start of the morning it is really hard to start alot of cranking. Once its has been started once it fires up like nothing. The fuel pump is pumping, the accelerator pump is squirting fuel before you start it. I am going to check the choke again and see. I will report later on and tell you my findings. Thank you so much for the procedure PhillipsLT5
![]() Join Date: Mar 2010
This forum would be a great help: http://forums.performanceyears.com/forums/index.php
1992 #043, Aqua/Gray 40k miles |
#7 | |
cranks a lean mixture.
