Old 07-20-2011   #1
Mike1952
Default newbie injector question
I have a 90 ZR1 with about 16k miles that I have original injectors still installed. Which injectors do you recommend to keep the ethanol at bay? David you have a post to a site for injectors but you didn't say which set you were recommending. I have a slight miss at 4k throttle and up sometimes and I am sure it is related to injectors.
TIA, Mike
Mike1952 is offline   Reply With Quote
Old 07-20-2011   #2
Kevin
Kevin's Avatar
Default Re: newbie injector question
rc or fic
Old 07-20-2011   #3
I believe if using the FIC injectors the preference is the "new" not the rebuilt injectors....the price about doubles but I think it's worth the POE to get new ones. JMHO
Old 07-20-2011   #4
I agree Tom!
FIC (new SS ones) They just started making Stainless Steel injectors recently and these are probably the best for long term use.
Old 07-20-2011   #5
Mike1952
okay remember I'm a newbie....where do you buy them and is there a part number I need. What should they cost?
Mike
Old 07-20-2011   #6
Mike
Mike,
Sorry!
http://fuelinjectorconnection.com/sh...&productId=208
Old 07-20-2011   #7
Mike1952
thanks David. Do those come with seals? Anyone in particular for plenum gaskets?
Mike
Old 07-20-2011   #8
Mike
http://jerrysgaskets.com/store2/root/ Jerry can fix you up with the soft goods and a lot of hardware also.
An alternate source is also:
http://whiteracingproducts.com/
Old 07-20-2011   #9
Mike,
I recommend using Viton over Buna for ethanol blended fuels, which is virtually all you have in Texas. here's a short list of the items needed to replace the injectors.
http://jerrysgaskets.com/store2/root...&products_id=7
http://jerrysgaskets.com/store2/root...roducts_id=384
http://jerrysgaskets.com/store2/root...roducts_id=387
AND.... here is a tech data link for info to replace the lower primary injector seal. You can download this to your computer and/or print it out to refer to while you are working.
http://jerrysgaskets.com/store2/root...roducts_id=446
Old 07-20-2011   #10
PhillipsLT5
PhillipsLT5's Avatar
accel injectors
