Old 07-19-2011   #1
Jagdpanzer
Jagdpanzer's Avatar
Default WTB LT5 Ignition Module
Looking for a LT5 ignition module - GM part# 1103841
Last major part needed for the 402 CID stroker build.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 07-19-2011   #2
Default Re: WTB LT5 Ignition Module
http://jerrysgaskets.com/store2/root...roducts_id=493
1 left
I know someone else who has some from the plant
Old 07-19-2011   #3
Jagdpanzer
Jagdpanzer's Avatar
Thanks Lee, I'm aware of this one at Jerry's but was hoping to find a latter 1103841 production one.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 07-19-2011   #4
Oh you want to keep the 402 as original as possible, got it
Old 07-19-2011   #5
ScottZ95ZR1
ScottZ95ZR1's Avatar
Sent you a PM on the other forum, Phil.
ScottZ95ZR1 is offline   Reply With Quote
Old 07-19-2011   #6
Is there a difference in the actual module....quality, pins, etc?
Old 07-19-2011   #7
WVZR-1
I'd think there must have been. The original preproduction ICM required an air-gap of something near .070 at the crank sensor I believe. That was accomplished with various thickness specialty shims. These early ICM's were reportedly used in only the first 500 production cars.
The early ICM was never offered as a service part. If an ICM failed it got the newer and the crank sensor's air-gap was adjusted
Whose got #501?
