Old 07-09-2011   #1
Default Ported Intake
x
Old 07-09-2011   #2
Default Re: Ported Intake
x
Old 07-10-2011   #3
WVZR-1
I have a fully ported Plenum I/H set ready for go on an exchange basis.
35mm ball passes completely through on primaries.......
IHs are blasted to aluminum and read for paint and PC
Can blast plenum also
$700 plus your INJ Housings and Plenum
Shipping not included
I would think IH casting #'s could be important to prospective buyers.
Old 07-10-2011   #4
Why? Besides, Lee doesn't remove any material from outside the IH and media blasting just cleans up the surface.
Old 07-10-2011   #5
x
Old 07-10-2011   #6
WVZR-1
I would guess that if these were '90-'92 MY the primaries were sealed to the injector housings with an o-ring in the IH. Correct? That's just what I recall!
I recall that later injectors could be used and that these seals (that aren't readily available) seldom failed so it's been generally accepted to inspect and use the later injectors removing the lower seal.
I don't know that Jerry has these sealing rings or not.
Were I in the market I would certainly like to know.
I thought it a relevant question. Maybe NOT!
Old 07-10-2011   #7
x
Old 07-10-2011   #8
WVZR-1
Nope, only 0 rings are the fuel injectors.....IHs use normal gaskets.
I checked Jerry's and he has early sealing rings! Perhaps this would be a "GOOD READ"! It seems to me this should answer the WHY!!!!!
https://jerrysgaskets.com/store2/roo...on%20Guide.pdf
Just post the casting information. What's the big deal?
Old 07-10-2011   #9
x
Old 07-10-2011   #10
WVZR-1
You see this comment contradicts the '90-'92 MY primary injector application. Right? Did you do the "read" I suggested?
Can early IH's be modified to accept primary o-rings on the injectors? Don't know and have never seen comments relating to it.
Was there interest on my part? Not now!
