Old 07-02-2011   #1
Default Clutches, plugs, n other stuff...
Dave Johnson (owner of the blue NINJA TURTLE) and I were talking about his Fidanza flywheel and clutch disc options. I mentioned to Dave that mine, with the guidance of friends here on this site, installed and works quietly without a hitch. He asked about parts used and related part numbers, and I thought I'd post them here for y'all, in case someone is interested...
I got my Veleo pressure plate from AutoZone, lifetime warranty for about $250 a couple years ago. It sold under the name "Duralast". Veleo pressure plates are no longer made - company went belly up, is the rumor. Bob G is using a push-type (dual disc) setup from RAM at a really decent price. (Bob or Pete would be the ones to ask for details.)
The Fidanza, being aluminum, requires longer thread than the stock cast iron FW. AND, the shearing load is best addressed by the shank of the bolt near the top of the thread (where the bolt enters a recess in the FW intended for that purpose). APR bolts are available as a kit from SRP. The kit I got included the proper drill bit and tap needed to drill and tap the FW** for the added length. Cost is $100 + S&H. Some have used grade 8s from the local hardware store - apparently without problems mention here (if any). I went with SRP's bolts.
Sprung - hub clutch disc from Centerforce. Part # 381039 from Summit Racing; $199. It is actually a part number for a late 90s LT1 Camaro or Firebird. The sprung hub goes a long way toward quieting in conjunction with the single mass aluminum FW.
Speaking of clutch repairs, worth mentioning is Bill Boudreau's C-beam plates - if for nothing else - are worth every penny just to ease removal and re-installation of the C-beam. AND, if you've experienced some squirming or "kicking out" of the rear end on hard acceleration, there's a good chance the holes in your beam have become elongated and the differential is squirming under load (causing at least some of the stability issue). I can attest to a significant improvement in stability since I installed the plates (on the Z and my previous LT1 car). (BTW, my C-Beam holes were "egged" a bit - noticed on my first inspection - attesting to the stability issue.)
Here are a couple more commonly discussed here, and their part numbers (for parts that seem to work well with my mods...)
The new GM part number for the knock sensor for the 90 LT5 (sensor is MY specific, apparently) is 216-94. (Old number = 10456075)
Had some guys experiencing oil pressure switch failures; getting brittle and blowing out to spray oil on the headers! It is a common switch that controls the oil light on the dash: AutoZone part # PS 206
Spark plugs: Opinions vary, but believe it or not, the standard copper AC/Delcos #41-602s are cheap and work well...Don't think so? Ask Pete what his green monster is running! (BTW, Pete has a picture hanging in his shop of his car lifting at least one front wheel, and that was with DRs and the standard 3.45 rear gear too!)
Accel injectors, Part# 150821 from Summit Racing, cost $588 +S/H for 16.
PVC valves:
Left side (GM) = CV769C
Right side = CV913C
I lost my GM part number for the coil packs and spark plug wires, which would be nice to include here. (Feel free to add to this list!)
Well, Dave.... I hope this answers yer questions.
P.
PS: Mebby one of y'all can help me too: Some time ago someone posted a site link to a Weather Pack connector dealer that had a list of part numbers for the LT5/ZR-1. Anyone happen to have that? (I need to replace a few connector plugs - dang 20 year old brittle SOBs...)
TIA,
P.
Old 07-02-2011   #2
ScottZ95ZR1
ScottZ95ZR1's Avatar
Default Re: Clutches, plugs, n other stuff...
TIA,
P.
May not include the specific site you're looking for but here are a few links I've saved from connector related threads over time:
http://www.acdelcotechconnect.com/pi...s/gm/pigtails/
http://www.casperselectronics.com/store2/
http://www.rs-autosport.net/catalog/...roducts_id=192
http://www.rowand.net/Shop/Tech/Auto...Connectors.htm
http://www.weatherpack.com/
ScottZ95ZR1 is offline   Reply With Quote
Old 07-02-2011   #3
Paul
Great write up!!!!!
Thanks
PS. Beware of the turtle!
Old 07-02-2011   #4
Originally Posted by ScottZ95ZR1 View Post
Thanks very much!!!
I love this board. Can anyone imagine what maintaining a ZR-1 would be like without this board and the internet??? I'm sure there'd be a lot more Zs under tarps in various barns around the country, if that were the case!
P.
Old 07-02-2011   #5
bdw18_123
Looks like another great post for the "Solutions" sticky, if there isn't already one with this info there. Dynomite?
I'll add that you can also get rebuilt Bosch II fuel injectors from Jon Banner at FIC. They are only $349 + S/H, and they are what I have for my '90 Z. Link here:
http://fuelinjectorconnection.com/sh...ewCat&catId=68
Jon is a great guy and he knows his stuff. My Bosch II's came with my Z and were sitting for a long time, Jon cleaned and flow tested them for me for FREE, all I had to pay for was shipping them to him.
Old 07-02-2011   #6
HAWAIIZR-1's Avatar
Thanks for posting P, great information and added to my rucksack. Thanks also to the others that are adding valuable information. I know that I would have never purchased my ZR-1 without the help of this site and also would not be able to keep the Heart of the Beast alive.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
HAWAIIZR-1 is online now   Reply With Quote
Old 07-03-2011   #7
carter200
carter200's Avatar
Any recommendations on plug gap for the 90-92 and the 93 and above? Thanks
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
ZR1NET Founding Mem #155
Old 07-03-2011   #8
I use the 41- 602's in my 90 gaped at .035 and they seem to work just fine.
This link is from Lee. They sell clutch parts for our cars.
http://powertorquesystems.com/
This is the thread Lee started about that company.
http://www.zr1.net/forum/showthread.php?t=15023
Old 07-03-2011   #9
carter200
carter200's Avatar
Tom,
Thanks, well, at least got half an answer
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
Old 07-03-2011   #10
When it comes plugs let me recommend doing plug cuts and inspecting the ground strap for proper heat range. On my 92, I found the 41-602s to be a bit too hot. I use the NGK BRK6E. A step colder than the 602s . Important to get right heat range especially when tuning for WOT.
How you drive the car will be a factor. If you don't flog it, you'll likely need a hotter plug.
