Old 06-22-2011   #1
Don in VT
Default Amsoil viscositys
Hi,
I have searched the solutions link and read as much as I can find on the forum and I can only see the Amsoil 10/40 listed as the oil of choice. I have a low miles 90 (34K) and I am considering using Amsoil 5/30. Is this OK to use as well.
Thanks
Don
Don in VT is offline   Reply With Quote
Old 06-22-2011   #2
ZR1Vette
ZR1Vette's Avatar
Default Re: Amsoil viscositys
The Amsoil 10W-40 AMO is 100% what you should use...it has the correct formulation for a higher zinc and phosphorus mix needed for the LT5 engine. You have it right
Old 06-22-2011   #3
cvette98pacecar
Originally Posted by Don in VT View Post
Hi,
Thanks
Don
Here is the link, unless you are planning on driving your Z in the cold stick with the 10-40 high Z.
http://www.amsoil.com/techservicesbu...t%20Tappet.pdf
Old 06-22-2011   #4
PhillipsLT5
PhillipsLT5's Avatar
http://www.zr1specialist.com/HAT%20W...5%20Engine.pdf
