Old 06-18-2011   #1
secondchance
Default PCV "F" piece
Anyone got one for sale? Silicone version?
A friend of mine is looking for one.
Old 06-18-2011   #2
Default Re: PCV "F" piece
I think Kurt has nice reproductions
Old 06-18-2011   #3
VetteMed
I have a good used OEM rubber one, $35 shipped?
Old 06-19-2011   #4
xlr8nflorida
xlr8nflorida's Avatar
If he does not want the F hose. I'm interested...
Old 06-19-2011   #5
Aurora40
Aurora40's Avatar
http://www.zr1.net/forum/showthread.php?t=14364
The Samco one is also a nice buy in that they should last forever and not get soft.
Bob Saveland
Former owner of #2517
Old 06-19-2011   #6
secondchance
Go for it xlr8nflorida.
Old 06-19-2011   #7
secondchance
Do you have a Samco piece?
Old 06-19-2011   #8
limey
You can't use the SAMCO "F" hose by itself, they will not line up with the stock lower hose. If you want the Samco PCV Hose, you have to buy them as a matched set both upper and lower $169.99
If you want the stock OEM "F" hose $49.78
[SIZE=3][B][COLOR=Red]Worlds largest ZR-1 LT5 Parts Store[/COLOR][/B][/SIZE]
[URL="http://whiteracingproducts.com/"]http://whiteracingproducts.com[/URL]
New & Used Parts, as well as free Locator services.
[EMAIL="sales@whiteracingproducts.com"]sales@whiteracingproducts.com[/EMAIL]
(813) 264-6368
limey is offline   Reply With Quote
Old 06-20-2011   #9
I like the samco hose im using as well. The original had to ziptied down to avoid coming off
Old 06-21-2011   #10
Aurora40
Aurora40's Avatar
It went with the car. If you use the upper and lower, be aware that it is not a perfect fit. It pulls the hard lines from the IH's back more. It tore one of my 90-degree elbows from the IH. The replacements are definitely "pulled" more too, though they haven't torn or pulled out.
You need to make sure that little bracket on each hardline is working properly, as that is what will keep it from pulling too hard on the elbows. They seem to break pretty easily though at the weld, especially when tightening the plenum bolt that holds them, it tends to rotate that bracket against the pipe.
The samco stuff ultimately worked just fine, but it was a little more of a pain than the stock stuff.
Bob Saveland
