06-13-2011 | #1 |
Rod Bolts
Well, I broke down and bought the Marc Haibeck Rod Bolts......some say the rod bolts can be reused, like LS1, others not..
Lets hear your throughts..... I probably would have reused if I was using the rod stretch method, but will be using 22 ftlbs and then torque angle of 80 degrees(if I recall)
LGAFF 90 #966-150K miles-sold 92 #234-sold 1987 Callaway TT #17 1991 ZR-1 #1359 Last edited by LGAFF; 06-14-2011 at 12:22 AM. |
06-13-2011 | #2 |
Re: Rod Bolts
I would probably would have preferred to buy the new ones as well. I've had a small block spin a rod bearing before on thrice torqued rod bolts...granted the new owner of that car spun it to 8k a couple of times, but still, I had it to 7500+ more than a few times, but that was before the rebuild.
I would probably use the stretch method to check a few bolts to see how spec torque increased length. I don't know too much about torque-to-yield... at least not using an angle wrench as I don't have one. |
06-14-2011 | #3 |
Re: Rod Bolts
I used the bolt stretch method on Marc's bolts. Since the oem's are torqued to yeild, I wouldn't reuse them. If I remember right, the arps should not be reused either, unless the stretch method is used.
[FONT=Comic Sans MS][COLOR=red]"I wanna go fast!!"[/COLOR][/FONT] [FONT=Comic Sans MS][COLOR=#ff0000]-- Ricky Bobby[/COLOR][/FONT] |
06-14-2011 | #4 |
Re: Rod Bolts
Lee,
I'm with you and broke my piggy bank to get Marc's rod bolts too. I did not want to take any chances and thought that con rods and bolts take on the most stress in the bottom half. I did a lot of better safe than sorry since I was building my own motor and did not have enough experience to consider otherwise. Call me Paranoid with a capital P; my rod bolts were considered somewhat new coming from a crate motor takeoffs for the rods and pistons I bought, but still previously torqued regardless.
Craig "ZR-1 NO KA 'OI" "ZR-1 ICHIBAN" 1995 #228 Black/Black with Dunn Heads ZR-1 owner since September 2003 ZR-1 Net Registry Founding Member #0074 NCM Lifetime Member #2048 Last edited by HAWAIIZR-1; 06-14-2011 at 10:22 AM. |
06-14-2011 | #5 |
Re: Rod Bolts
Additionally:
How much rpm/ piston speed is too much for the LT5? If you stretched the old rod bolts at all, do the rods need to be re-sized? If they are already egg shaped, the new bolts might not help. Then again, if you didn't have a lower end failure when the engine came out, everything may still be ok. |
06-14-2011 | #6 |
Re: Rod Bolts
the lt5 was designed to go to 8k+ if I remember correctly but the accessories wouldn't handle that. if i'm rebuilding a motor that I beat on as hard as I do my lt5 i'm not taking chances
06-16-2011 | #7 |
For the record...
For the record, anytime new/different rod bolts are to be, the rods should always be re-sized.
There are no limit's mans ingenuity, just as mans ingenuity will never conquer the forces & behavior of this planet...Smokey Y. |
