Old 06-12-2011   #1
Default Loctite 262
Can't find it can I use 271, where it calls for 262 or will that be too strong?
Old 06-12-2011   #2
Default Re: Loctite 262
See if you can find Loctite 263. It's the same strength as 262, except that it already has primer.
I'm in the process of becoming approved as a jobber for Loctite and will be listing 242/3 & 262/3 on the website. A couple of the guys at BG told me it was a pain to find and run around to get it.....suggested that i keep it in stock as a convenience item.
Old 06-12-2011   #3
No luck on 263, will check with my machinist on Monday
Old 06-12-2011   #4
lbszr
lbszr's Avatar
This is the company I purchased some a few years ago.
http://applied.findlocation.com/results.aspx
[FONT=Comic Sans MS][COLOR=red]"I wanna go fast!!"[/COLOR][/FONT]
[FONT=Comic Sans MS][COLOR=#ff0000]-- Ricky Bobby[/COLOR][/FONT]
Old 06-12-2011   #5
lbszr
lbszr's Avatar
They might not have 262 anymore, but here's the 263 that A26 mentions.
http://www.applied.com/apps/commerce/catalog/catalog.do
Old 06-12-2011   #6
Jagdpanzer
Jagdpanzer's Avatar
I get 262 at my local Fastenal store
http://www.fastenal.com/web/products...u=62404&ucst=t
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 06-12-2011   #7
bdw18_123
I got my 262, 242, 565 & 518 (substitute for Permabond A136) from a couple of companies selling through Amazon.
[IMG]http://i13.photobucket.com/albums/a292/bdw18_123/_zr1netforumsigphoto.jpg[/IMG][B]
1990 Corvette ZR-1 [/B][I]
White/Flame Red, #2299, mostly stock, 144K miles.[/I]
-Cams timed to the '93-'95 405HP LT5 stock timing.
-IAT sensor relocated to below front bumper.
-Haibeck hoops installed in airduct.
-OBX cat-back exhaust.
[COLOR=DarkRed][B](SOLD - December 2012 [/B][/COLOR][COLOR=DarkRed][B]:hello:)[/B][/COLOR]
1993 Corvette Coupe
Black/Black, 6-speed
(SOLD - October 2009 :hello:)
Old 06-13-2011   #8
RICHARD TILL
I`ve got two nearly full bottles. 1.69 fl. oz. They use it on each little job where i work and leave the remainder of the bottle to be thrown away. Thats when i come into the picture. If you don`t have any luck finding any, let me know and i`ll mail you one of em.
Old 06-13-2011   #9
Thanks for the offer; got the last bottle at Fastenal store
Thanks Phil!
Old 06-14-2011   #10
HAWAIIZR-1's Avatar
I see you have it resolved, but for what it is worth, here is the answer I received when I had a problem finding 262 in Hawaii. This is from Loctite Tech USA Industrial Dept:
Craig,
Loctite 262 is approximately 40% less strength in both breakaway and prevailing strength than Loctite 271 on steel fasteners. The fixture time is a little longer with Loctite 271 vs 262, 10 minutes and 5 minutes respectively. The viscosity is lower with Loctite 271 than 262, 500 cps vs 1850cps. Other than that the temperature , gap filling and sizes of fasteners are about the same. Hope this has helped you.
Take Care,
Tom Kosloski
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
