Old 06-06-2011   #1
Default nick in valve
When putting the heads together noticed this:
small nick in valve, I assume from when the engine ingested a small screw, any thoughts if this is a concern....valve is not bent. I assume it will not be an issue
LGAFF is online now   Reply With Quote
Old 06-06-2011   #2
Default Re: nick in valve
I've no specific info on valve shanks specifically, but eliminating sharp edges, i.e., smoothing or rounding, is SOP for crack deturants for engine blocks and sleeve edges, and the leading edge on aircraft propellers too, for that matter.
So, if you hafta use that valve, then smoothing the divot so as to remove any edges would be in kind with what is done in some other situations where cracking is at issue.
I think I would get another valve first, if at all possible. JMO
FWIW,
P.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 06-06-2011   #3
mike100
If that nick doesn't pass thru the seal, that's probably usable, and I probably would on some 200 hp engine, but I too would try to find a replacement given the attention to detail you have into the project so far.
Old 06-07-2011   #4
carter200
carter200's Avatar
FWIW,
P.
I agree with Paul. What is the cost of a valve to all you have done and will do. Just put in a fresh valve and move on. That mark will be bugging you forever, if not.
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
ZR1NET Founding Mem #155
Old 06-07-2011   #5
From an ROI standpoint, no question. Get another one. Just not worth it.
Old 06-11-2011   #6
Polo-1
Lee do you need a valve or 2 ?? I got a bag of them. Let me know.
Old 06-11-2011   #7
Thanks.....will be replacing it...got a bag of them too with Paul D estate auction.
Old 06-11-2011   #8
Jagdpanzer
Jagdpanzer's Avatar
Smart decision Lee, no need to take the risk.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
