Old 05-30-2011   #1
Default Car wouldnt start........what say the Brotherhood?
I stopped by my brothers house earlier today,got ready to leave and the car wouldnt start.Batteries maybe 6 months old,Alt is charging,turn key and the Security light goes out but no start.Im thinking either clutch safety switch or the starter gettin funny.I jumped it with a battery charger and it starts right up.Drove the car home,put it in the garage and the car starts right up.I drove the car for a few miles yesterday but other than a short drive every other week dont really drive it that much.Why would the car start with a jump from the battery charger?If the starter is acting up would the extra juice from the jump jolt the starter to work?I thought the VATS might be acting up but from what Ive read if the Security light goes out when the key is turned to start the Security light will go out.Id like to think this was a freak occurrence but would like to find out whats goin on here.What say the Brotherhood?
Old 05-30-2011   #2
mike100
Default Re: Car wouldnt start........what say the Brotherhood?
not LT5 specific, but sometimes a boost in battery voltage will get a sticky solenoid to close with a little more authority.
You should load test that battery next time it doesn't start. A fully charged battery that has sat for a few days should still read 12.6v. If that battery is around 4 years of age, you might replace it for gp, even if it turns out the starter has problems.
Old 05-30-2011   #3
cvette98pacecar
It is the VAT key. I had the same problem with a 92 ZR1 that I owned before. I'll Bet that you took the key out of the ignition while you connected the battery charger. Have a new key cut or buy the VAT bypass.
Old 05-30-2011   #4
I may have takin the key out of the ignition with the charger connected,I know I was wiping the $hit outa that pellet.Ive got an extra set of keys and one extra key I have cut right after getting the car.
Old 05-30-2011   #5
Kevin
Kevin's Avatar
my advice is to always bypass the clutch switch. costs $0.15 and then if that doesn't work you can move onto other stuff
Old 05-31-2011   #6
Jeff have you bypassed the clutch switch yet? GC
Old 05-31-2011   #7
I havent done this yet,would like to put a bypass switch in line without cutting anything.I can get some OEM plugs and put something together.How common is the clutch switch being a problem?Cars got 17,000 miles but sometimes mileage doesn't matter when it comes to failures.
Old 05-31-2011   #8
tccrab
tccrab's Avatar
Jeff:
The DNS (Dreaded No Start) can come for many different reasons.
Clutch safety switch is a common failure and easily bypassed.
Corroded battery terminals are another biggie.
Could be a funky starter too, especially if the engine has ever been wet at any time in its' life.
I don't recommend hacking your wiring harness and installing my patented DNS Cure just yet.
Rule out the obvious, less invasive remedies first.
Don't think it's a VATS issue, sounds like everything is working as it should.
The following is the VATS sequence on startup:
When the system is operating in normal mode, the VATS decoder reads the correct resistance during cranking. The module grounds the Start Enable Relay coil. When the start enable relay contacts close, voltage is allowed to the "S" terminal of the starter. The VATS module also sends an enable signal to the ECM. This signal allows the ECM to operate the fuel injectors during cranking. The SECURITY light will also illuminate for approximately five seconds, then turn off and remain off. If an incorrect or no key resistance is read by the VATS decoder module, the module will shut down the start enable and ECM signal outputs for 4 minutes. The SECURITY light will flash during the cranking attempt, and will remain on during the 4-minute duration. Even if the correct resistance is read within that 4 minute duration, the VATS module will not operate the relay or signal the ECM..An error code.53 will also be set if the proper signal is not being received on CKT 229 by the ECM when the ignition is turned ON.
If an incorrect resistance is detected by the VATS module after the engine is running, the VATS module will allow the vehicle to be restarted, even with an existing failure. The SECURITY lamp will remain on to warn the driver that a VATS system fault is present. However, this also means that the car can be started w/o a correct key resistance, and is therefore vulnerable to theft. An error code.53 will also be set by the ECM in this mode.
TomC
'Crabs
Old 05-31-2011   #9
Kevin
Kevin's Avatar
Pull drivers side hush panel. Find Purple wire that goes to clutch
switch. Look at switch and note the color of wire coming back
up.(Yellow??) Will be able to jumper them right there. I used a 3 in
wire with terminals on the end and unplugged the wires going to switch
and plugged in the jumper wire. Use a 12 ga wire at least as it does
carry a heavy current load which is why the switch fails, it gets hot
and the resistance across the points stops current flow.
unless someone is really really digging into your car no one will ever see it
Old 05-31-2011   #10
What Kevin said 100%
The previous owner of my car did this after being stuck 3 times. It has never been a problem since
