Old 05-27-2011   #1
Default Twin Disc Clutch Setup: McLeod-2 Avail
The are used from the Paul Dehnert collection
McLeod Dual Disc Set:
1)Aluminum Flywheel setup: Retails for over $2000
....$400 OBO/Will put the newer disc from steel setup for $470.00
2)Steel Flywheel Setup: Retails for over $1700
Next to new..... slightly used....$400
Per Marc H.....these are great setups...see the note in the tech section
Old 05-28-2011   #2
Scrrem
Scrrem's Avatar
Default Re: Twin Disc Clutch Setup: McLeod-2 Avail
GC,
I'll take this one with the new disc. PM inbound.
....Will put the newer disc from steel setup for $470.00
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 05-28-2011   #3
Sale pending
Old 05-28-2011   #4
youngrm
please let me know if the sale does not transpire and if it does will the price be changed for the scavenged (remaining) set up?
thank you
ric young
youngrm is offline   Reply With Quote
Old 05-28-2011   #5
I will let you know, thanks
Old 05-28-2011   #6
zrss
Put me third in line for the aluminum flywheel setup.
zrss is offline   Reply With Quote
Old 05-28-2011   #7
Steel setup is a hefty 65lbs......aluminum weighs in at 28lbs
Old 05-29-2011   #8
Not part of th deal but I freshed up the setup...looks nice, and made sure the flywheel is set up as balanced by the factory:
before:
After:
Old 05-29-2011   #9
Any interest in the Steel clutch, discs are slightly used, but the flywheel and internals are like new.....I will clean up just like the last one
Was looking for 350 plus shipping
Old 05-29-2011   #10
youngrm
The aluminium sold?
Thank you
Ry
