Old 05-06-2011   #1
lbszr
lbszr's Avatar
Default Oil pump type?
Does anybody know if the pump is a gerotor or gear design, or have pictures of the inside of the oil pump? Just courious.
Old 05-06-2011   #2
Default Re: Oil pump type?
In the FSM the blow up picture shows a gear within a gear type. Isn't that a gerotor type pump vs the old fashioned meshed gear type in the old sbc motors?
Old 05-06-2011   #3
lbszr
lbszr's Avatar
Thanks for the info where to find it. I didn't see it in the supplement and didn't think to look in the big book. I think your right, looks like a gerotor.
Old 05-07-2011   #4
HAWAIIZR-1's Avatar
Here is photo of the inside of the pump when I rebuilt mine.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 05-07-2011   #5
lbszr
lbszr's Avatar
That's some flowand thanks for the picture, that must be part of the reason these lt5's are hard to break.
Old 05-07-2011   #6
shaynezrl
shaynezrl's Avatar
Craig,
How was rebuilding the pump? Was it something hard to do? I am thinking of doing the same thing to mine.
shaynezrl is offline   Reply With Quote
Old 05-08-2011   #7
HAWAIIZR-1's Avatar
You're welcome. I think you are right about our oil pumps and not sure there has ever been a failure on one of these.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
Old 05-08-2011   #8
HAWAIIZR-1's Avatar
Originally Posted by shaynezrl View Post
Craig,
Shayne,
Here is a post I did on a blog about the rebuild if it will help you.
http://blogs.yahoo.co.jp/corvettezr1....html?m=lc&p=4
The page before towards the botton explains the carbon seal replacement and that is vital; thanks to Jerry for all his technical advice on this and recommending the new seal:
http://blogs.yahoo.co.jp/corvettezr1....html?m=lc&p=3
To be honest, I think I was being very anal when rebuilding mine and I can't even imagine how these could fail other than the carbon seal side? I am sure I would have been fine, but since I was doing a rebuild it seem the right thing to do and hardly worn inside from visual inspection. Just old school and when rebuilding the SBC or BBC I used to always put in a new oil pump. Since I had a new OEM late model pump I just swapped the guts out to be able to sleep at night and hopefully with all the redline WOT the LT5 will stay together.
Best wishes.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
Old 05-08-2011   #9
shaynezrl
shaynezrl's Avatar
Craig, Thank you the links you did a great on the write up. I admired your patient and skill.
Shayne
Old 05-08-2011   #10
HAWAIIZR-1's Avatar
Shayne
You're welcome and thanks for your thoughts. I still can't believe I rebuilt the LT5 myself, but it was a great learning experience and good feeling.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
