Old 05-04-2011   #1
John Boothby
John Boothby's Avatar
Default Rear sway bar
Had my 90 serviced yesterday and asked that they check the suspension system. No problem, just 75K on car.
Mechanic said I need "rear sway bar links and bushings" and quoted $535 parts and labor. Is this a fair price? It is a local Chevy dealer.
Thanks
JB
1990 #148 Red/Saddle
Haibeck AYBKG5 Chip/RC Engineering/Flowmasters/K&N/Samco/Fuzzy Dice
:cheers:
John Boothby is offline   Reply With Quote
Old 05-04-2011   #2
Scrrem
Scrrem's Avatar
Default Re: Rear sway bar
Thanks
John,
Seems a bit steep to me, maybe others can chime in. I have those very parts on order, getting ready to do the job myself. The bushings total are about $30.00. I believe you need a press to get the upper link bushing pressed out of the sway bar, but not a reall difficult job.
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 05-05-2011   #3
John Boothby
Thanks. He mentioned that they had to press the bushings in/out. He said it was easier to just replace the links also. Let me know how you do with yours.
JB
:cheers:
Old 05-05-2011   #4
Scrrem
Scrrem's Avatar
Will do John....the bushings arrived yesterday. I probably won't get to installing them before departing for BG, will tackle when I get back. Also, I think I ordered the wrong size sway bar bushings, may need to re-order those (ordered 26mm, should have been 24mm). Doing everything in the rear, bushings area pretty shot after 20 years.
Rich
Ron Davis Radiator
