Old 05-03-2011   #1
vinsZR-1
vinsZR-1's Avatar
Default Noise at idle
I'm getting what sounds like a bird chirping at idle. Any ideas on what pulley it can be ?
Vince #1966
vinsZR-1 is offline   Reply With Quote
Old 05-03-2011   #2
QB93Z
QB93Z's Avatar
Default Re: Noise at idle
The usual suspects are the idler pulley, the alternator, or the water pump.
I would start trouble shooting by removing the serpentine belt and spin each pulley by hand. The slight noise you hear may not be detectable at hand spin speed, but you might get lucky and find the culprit.
Another tool is a mechanics stethoscope. I got one at Sears. Just be very careful sticking the probe in the belt area when the engine is running.
The easiest to replace is the idler pulley. I have a good used spare that I will ship to you if you want to try and swap it out to see if it is the source. All I ask is that you ship it back to me at some point.
Old 05-03-2011   #3
For reference, in case you ultimately need something.
Belt Tensioner Pulley
http://jerrysgaskets.com/store2/root...roducts_id=573
Complete Belt Tensioner
http://jerrysgaskets.com/store2/root...roducts_id=572
Alternator
http://jerrysgaskets.com/store2/root...9e08c715b063ac
Water Pump
http://jerrysgaskets.com/store2/root...products_id=45
Old 05-03-2011   #4
Vince #1966
Mine was making a chirping noise and I couldn't find much by turning the pulleys by hand. I had a new belt & figured what the heck. The belt on the car was six yrs old & had 37+ thou on it so I swapped it and the chirp was silenced.
Old 05-03-2011   #5
Old 05-03-2011   #6
| 1990 ZR-1 |
I also had a slight chirping during idle, and after replacing the belt, it went away.
What happens is that the surface on the pullies tends to rust during the the engine is not running, and when you start the car up, that rust tends to smear on the belt surface and create a very fine metalic film which is actually visible in between the V grooves on old belts. So it's almost like metal rubbing against metal, hence the squicking sound. If the belt is old, 99% of the time that's the cause.
| 1990 ZR-1 | is offline   Reply With Quote
