05-02-2011 | #1 |
Digital Display
The digital display on my instrament cluster is missing segments. As the speed changes the missing segments change. I have checked all my grounds and think the problem is in the display itself. Dose any body no where I could get it repaired or exchanged. Also any ideas on how to fix it would be even better.
Matt |
05-02-2011 | #2 | |
Re: Digital Display
Also when you turn the key on and the LCD self-tests are all the segment lit up or the bad ones still showing up?
05-02-2011 | #3 |
Re: Digital Display
1991 the segments are bad all the time even when they test them selfs
Matt |
05-02-2011 | #4 |
Re: Digital Display
I have had one go bad in my last car. best bet is buy a used 90-91 cluster and use the LCD from it, I don't know of any places that repair them, if there are I have one that needs to be fixed too
05-02-2011 | #5 |
Re: Digital Display
http://www.corvettedashclusterservic...nfo90to93.html
http://www.digicontrols.ca/instrument.html http://www.mamotorworks.com/corvette...1-54-7898.html TomC 'Crabs
05-02-2011 | #6 |
Re: Digital Display
These guys fixed wifey's 91 L98 cluster about 4 years ago and it's still going fine:
http://www.instrumentclusters.com/ just down the road from you.
05-02-2011 | #7 |
Re: Digital Display
Thanks for all the links I check them all out
Matt |
Tags |
cluster, digital, display, instrument |
