![]() Join Date: Mar 2007
Who is selling the AM rings for the LT-5, my machinist said he would get new ones...
#2 | |
![]() Join Date: Dec 2003
WTH are AM rings? Pete
AM=Aftermarket......Piston Rings
Lee,
You will need to carefully check these rings out. The compression rings have a history of being too thin, resulting in side clearance on the top side of acceptable. They also are not as wide as stock rings, meaning they are not as well supported in the ring groove when compressed. They will work, but short life due to flutter & ultimately breakage, may occur. If you buy them, please let us know your findings.
I am unsure if total seal have these rings anymore, so you may not be able to source them direct, however we do have plenty in stock if you want them. $249.99 per set.
I have sold these ring kits for 3 + years now and never had one issue with any customer, i've assembled motors in house and never had any issues with fitment. I found out about these rings through Marc and to get the word from the horses mouth it would be best to ask him, but... i am certain he uses them in stock motors. I had one customer send a set back to me as he wasn;t certain he wanted to put these in his motor, that's fine we took them back, but i wouldn't hesitate in putting these Total Seal ring kits in any motor and would be happy to do so all day long. I can't say i have heard of any engine with these rings go 100,000 miles, but on the other hand i haven't heard of any failing after 1000 miles. |
As a matter of clarification to the subject of my fitment post above, I do NOT have any personal experience with the fitment of the subject rings, nor did I know that Kurt sold Total Seal Rings. The information I provided was from two independent sources and was meant as a cautionary advisory.
If Marc Haibeck says they're good to go in a stock piston, then I'm sure he has checked fitment thoroughly and found them serviceable.
I checked into the issues, I was told that I need to check, however the issue was brought to their attention and supposedly has been fixed, the cost is $309.00
But as noted, no one has come forward with issues from the orginal rings
LGAFF 90 #966-150K miles-sold 92 #234-sold 1987 Callaway TT #17 1991 ZR-1 #1359 Last edited by LGAFF; 04-28-2011 at 01:29 PM. |
#9 |
![]() Join Date: Aug 2006
#10 |
Sorry AM is the abbreviation used in estimating for insurance claims when an aftermarket part is used.....
