Old 04-24-2011   #1
sammy
Default i am doing a secondary delete tomarrow for....
a friend . we have marks prom allready . is there any tip someone can share as to the best way to wire open the secondaries .thanx for any help you can provide
Old 04-24-2011   #2
Default Re: i am doing a secondary delete tomarrow for....
Dom did this fairly recently as did Andrew I believe
Old 04-24-2011   #3
ZR1@gmx.com
It is fairly straight forward to just remove the plates, bearings and all, then plug the holes. I think I have some photos I will try to dig up!
ZR1@gmx.com is offline   Reply With Quote
Old 04-24-2011   #4
sammy
the person i am doing it for doesnt want to remove the plates or butterflies as he will have to pass ca smog once every 2 years . do we have to remove the actuators? and what does everyone use to keep them open /?
Old 04-24-2011   #5
mike100
what if you leave the actuators for now and just hook them to manifold vacuum?
that will force them open to test out your chip function. Other than that, I almost want to suggest an old fashioned pull cable like on a choke for a carbed car. need to do it twice though.
Old 04-25-2011   #6
Well, a little easier than that, actually. Dom used a plastic tie-wrap to strap the throttle plates open.
Also, you then need the chip programmed to run the secondary injectors "full" time and halve the primary dwell time (closed loop). The vacuum line is disconnected from the vacuum sensor to be exposed to atmospheric pressure which the new program reads as "normal" i.e., no codes are thrown sans vacuum.
To return to stock, just snip the tie-wraps, swap the chip, restore the vacuum circuit and it's good to go.
But, ya know...I would be tempted to see if it would pass emissions testing with the secondaries open. The stock tune at the low end of the rpm band, according to Marc, is a little "fat" anyway. So...it raises the question: Will it pass regardless of the secondary system being nulled? Just a thought.
As for the "choke cable" scenario, that is intriguing! An external actuator, if you will, would eliminate a plenum pull. Tho pulling the plenum is a snap, (once you do it a couple times to establish a routine) the fewer times those connectors are pulled apart and reinstalled...the better, I recon!
P.
Old 04-25-2011   #7
Yep. But, that was on the car he wrecked. His "Roza Nero" has the secondaries removed entirely (he said last Saturday).
P.
Old 04-25-2011   #8
VetteMed
No secondaries here! Love it!
Old 04-25-2011   #9
When the new block goes in Im doing this as well. Andrew are there any SES codes when you do this ?
Old 04-25-2011   #10
VetteMed
First time around I had some lean codes, even with the Haibeck chip. However, those disappeared after new FIC injectors and new fuel pumps were installed. Not a peep out of the ECM since then
Andrew
