Old 04-14-2011   #1
aafc
aafc's Avatar
Default 1990 rear spring rates
Hi,
I want to change my rear spring in the ZR-1 to a softer rate . My
build sheet shows the front spring is code AA and the rear is NYR.
Question is were can i find the spring rates for say an L98,LT1, LT4 etc.
The car is used for drag racing 2 to 3 times a month, so i don't care
about road course time.
ZR1pete (fla) rpl his spring with a LT1 spring ,but he dose not know what the rate was. Were can i find the information that i'm looking for?
Thanks
John Becker
1990 black/white #2546
one of a few auto eq. zr-1's
aafc is offline   Reply With Quote
Old 04-14-2011   #2
lbszr
lbszr's Avatar
Default Re: 1990 rear spring rates
http://www.zr1netregistry.com/ZR1_suspension.htm
Hope this helps.
Old 04-15-2011   #3
Hog
Wow, those1984 Z51 suspensions must hammer pretty good.
peace
Hog
Old 04-15-2011   #4
lbszr
lbszr's Avatar
peace
Hog
I wonder if that one had an oversteer problem. It looks like they got away from the large high difference of the rear wheel rate over the front wheel rate later.
Old 04-15-2011   #5
aafc
aafc's Avatar
IBSZR
Thanks for the link to late model suspension chart. I was able to
convert the 92.2 n/m to lbs to get the spring rate. 92.2n/m x 8.850=815.97 lbs. So what i'm looking for is a rear spring that is 33.0 n/m
(292 lbs) or a 26.0 n/m (230 lbs I will check for c4 spring from a corvette
recycleing yard.
Thanks
John Becker
1990 white/black #2546
one of a few auto eq ZR-1's
