04-04-2011 | #1 |
Little White hose Clip thingy
Any else missing the little white hose clamp thingy that is over by the radiator cap/PS I believe it holds a vac line....I am going to try and make them.....just seeing if anyone else has the need before I start this project
Its the Vac tube clip that attaches to the small coolant tube that bolts to the plenum, will post pics later
LGAFF 90 #966-150K miles-sold 92 #234-sold 1987 Callaway TT #17 1991 ZR-1 #1359 Last edited by LGAFF; 04-04-2011 at 06:04 PM. |
04-04-2011 | #2 |
Re: Little White hose Clip thingy
I believe this is what you are talking about, Lee (red arrow):
Only the 91-95 ZR-1's have this. The 90 ZR-1's don't (see pic below). Does anyone know what this extra vacuum line is for that they added?
[IMG]http://i13.photobucket.com/albums/a292/bdw18_123/_zr1netforumsigphoto.jpg[/IMG][B] 1990 Corvette ZR-1 [/B][I] White/Flame Red, #2299, mostly stock, 144K miles.[/I] -Cams timed to the '93-'95 405HP LT5 stock timing. -IAT sensor relocated to below front bumper. -Haibeck hoops installed in airduct. -OBX cat-back exhaust. [COLOR=DarkRed][B](SOLD - December 2012 [/B][/COLOR][COLOR=DarkRed][B]:hello:)[/B][/COLOR] 1993 Corvette Coupe Black/Black, 6-speed (SOLD - October 2009 :hello:) |
04-04-2011 | #3 |
Thats it!
04-04-2011 | #4 |
I'll take one. While you're at it, make the black clip that holds the fuel lines bolted to the evaporator case.
04-04-2011 | #5 |
I would like one of each!
Fun 91 #303 |
04-05-2011 | #6 |
Id take at least 3
Rick |
04-05-2011 | #7 |
While you're at it Lee make some of the spark plug wire holders on the rear, I broke one of mine last week.
04-06-2011 | #8 |
I'll take a couple - mine is all loose and keeps popping out... errrr....
1991 #1516 Black/Black davidmkelly.com "Speed is often confused with insight." - Johan Cruijff |
04-06-2011 | #9 |
I believe that is a clip for the vacume line that goes to the charcoal canister for the fuel tank vapor recovery system on the later model LT5's. On the 90 that line comes out behind the A/C compressor and goes to the charcoal cannister under the left headlight.
04-06-2011 | #10 |
Please put me down for a couple, Lee.
