Old 04-03-2011   #1
Corvette95
Corvette95's Avatar
Default low mile 95 starter issues
My 7k mile 1995 started fine today, it sits for months at a time. When I cut it off and started it again, there is a no crank condition. There isnt a security light and it seems to be energizing the starter relay because voltage drops from 12.0 to 11.5 when the key is turned. So either the starter is going bad or the starter relay is going bad. Any quick test to determine which?
1994 C4 Coupe Wht/Blk SOLD
1990 C4 ZR-1 Red/Red #0454
Old 04-03-2011   #2
gbrtng
gbrtng's Avatar
Default Re: low mile 95 starter issues
If you're seeing only a half volt drop when you turn the key, the starter solenoid is drawing current but not pulling in to switch current to the starter. When the starter runs and cranks the engine the voltage would be about 10 volts with a healthy battery.
Listen carefully for noises at the starter area when someone else turns the key; you should hear the solenoid click.
Old 04-03-2011   #3
Corvette95
Corvette95's Avatar
So you think the relay is working but the solenoid is going bad?
