03-27-2011 | #1 |
OEM Replacement Head Gasket Question
I was looking over the pair of replacement OEM head gaskets I plan to use on the 402 build and noticed the left gasket PN# 10106177 is different from the the one that came off the engine. Both of the replacement gaskets have a tab for the right side head oil port however, the hole is not punched in the left side gasket. As you can see in the below photo the lower original factory installed gasket did not incuded this tab.
New gaskets
03-27-2011 | #2 |
Re: OEM Replacement Head Gasket Question
Yes,you have to trim that portion off.
This was on all OE gaskets. This is why we can use the right gasket for either side. Pete
'91 #1635 PoloGreen 350 LT5 11.09 @ 129.27 11.04 @ 128.86 474RWHP 400RWTQ http://www.youtube.com/watch?v=SFNFOhGGlR4 http://www.youtube.com/watch?v=ZlRIOMwaDYY https://sites.google.com/site/peteszr1garage Last edited by Pete; 03-27-2011 at 05:47 PM. |
03-27-2011 | #3 |
The OEM gaskets I had in stock for awhile, were trimmed already for the LH side. No hole was punched and no trimming required.
This is a serious snafu for an inexperienced engine builder that overlooks the oil passage on the RH side. I know of at least one LT5 meltdown on the RH cylinder head due to just this issue. LH side. sure....just trim off the excess inside the chain galley.
03-27-2011 | #4 |
I didn't realize that the new OEM left head gaskets had the right head oil port tab in it. So if that is the case, shouldn't you be able to also use the left head gasket on the right side as long as you drill the hole in that tab?
Because they are essentially exactly the same gasket, the only difference being that oil hole.
[IMG]http://i13.photobucket.com/albums/a292/bdw18_123/_zr1netforumsigphoto.jpg[/IMG][B] 1990 Corvette ZR-1 [/B][I] White/Flame Red, #2299, mostly stock, 144K miles.[/I] -Cams timed to the '93-'95 405HP LT5 stock timing. -IAT sensor relocated to below front bumper. -Haibeck hoops installed in airduct. -OBX cat-back exhaust. [COLOR=DarkRed][B](SOLD - December 2012 [/B][/COLOR][COLOR=DarkRed][B]:hello:)[/B][/COLOR] 1993 Corvette Coupe Black/Black, 6-speed (SOLD - October 2009 :hello:) |
03-27-2011 | #5 |
On the left 94 cylinder head I have there is coolant port (see below pic) on the deck surface mighty close to the outer edge of where oil port hole is located on the right side gasket. I'm affraid any leak there would end up draining into the cam chain gallery. On the other hand appears the left side gasket with the tab can be used on the right side cylinder head after being punched with the proper size hole for the oil port.
Phil Wasinger 1994 Torch Red ZR-1 WAZOO Member George Braml Intake Last edited by Jagdpanzer; 03-28-2011 at 04:36 PM. Reason: added photo |
