![]() Join Date: Jan 2006
A few years ago I went off a 25 embankment backwards at 70 mph into a grove of oak trees. It was black ice half way to Chicago from Detroit in the dark at 5:30 a.m..
![]() Join Date: Mar 2004
We strap the Z's down the same way Bill. This tie down method is fine.
The straps put a bit of tension on the exhaust but that is no big deal. There is allways the wheel straps and additional tie downs would have to be installed on the trailer floor. |
There are point in the rear for tie down straps for shipping from the factory. The front, you can use the lower A-Arm, althouhg I believe there is a factory tie down as well.
Jeff,
Really? Where do I look, and what am I looking for. Is it a loop? On the frame I assume. Thanks, Bill |
Please ignore the heinous purple caliper.
![]() Tie down point is just behind the dog bones. |
Jeff,
Wow! Thanks for your help, that goes above and beyond the call of duty. I assume you mean the oval shaped hole just above the lower silver arm forward of the rotor. If so, I also will assume it is for a strap hook and not for a strap with rings at each end. My D-rings are behind the car, probably just behind the bumper when the tongue weight is right. I will have to see how these attachments line up with the D rings so that I can feed the strap through without putting a bind on some part of the car. Thanks again for this Z lesson. Bill ![]() |
Wait till you X the straps from the factory tie down points
